Miles28 3 Posted March 6, 2024 Posted March 6, 2024 Emby server running on OpenWRT as a docker container restarting continuosly. Syslog: Wed Mar 6 09:12:18 2024 daemon.err dockerd[5354]: time="2024-03-06T08:12:18.822281849Z" level=error msg="failed to enable controllers ([cpuset cpu io memory pids rdma])" error="failed to write subtree controllers [cpuset cpu io memory pids rdma] to \"/sys/fs/cgroup/docker/cgroup.subtree_control\": write /sys/fs/cgroup/docker/cgroup.subtree_control: no such file or directory" Wed Mar 6 09:12:18 2024 daemon.err dockerd[5354]: time="2024-03-06T08:12:18.858580327Z" level=warning msg="cleaning up after shim disconnected" id=5a2febdeb66d3f12500e337359a3cf8c88bbef628554fa5242d23bc8012b3efa namespace=moby Wed Mar 6 09:12:19 2024 daemon.err dockerd[5354]: time="2024-03-06T08:12:19.466943108Z" level=warning msg="Failed to delete conntrack state for 172.17.0.2: invalid argument" Wed Mar 6 09:12:19 2024 kern.info kernel: [ 457.646923] docker0: port 1(veth20865a9) entered disabled state Wed Mar 6 09:12:19 2024 kern.info kernel: [ 457.653092] veth2e42ad8: renamed from eth0 Wed Mar 6 09:12:19 2024 daemon.notice ttyd[8297]: [2024/03/06 09:12:19:5900] N: rops_handle_POLLIN_netlink: DELADDR Wed Mar 6 09:12:19 2024 kern.info kernel: [ 457.766958] docker0: port 1(veth20865a9) entered disabled state Wed Mar 6 09:12:19 2024 kern.info kernel: [ 457.774920] device veth20865a9 left promiscuous mode Wed Mar 6 09:12:19 2024 kern.info kernel: [ 457.779948] docker0: port 1(veth20865a9) entered disabled state Wed Mar 6 09:12:19 2024 daemon.notice netifd: bridge 'docker0' link is down Wed Mar 6 09:12:19 2024 daemon.notice netifd: Interface 'docker' has link connectivity loss Wed Mar 6 09:12:19 2024 daemon.notice netifd: Interface 'docker' is now down Container log: stderr: importas: fatal: unable to exec export: Not supported Container Inspect: { "Path": "\/init", "ProcessLabel": "", "ResolvConfPath": "\/opt\/docker\/containers\/5a2febdeb66d3f12500e337359a3cf8c88bbef628554fa5242d23bc8012b3efa\/resolv.conf", "NetworkSettings": { "LinkLocalIPv6Address": "", "SandboxID": "49e92ff6ac731cdd39a3769f504b692343dc13d500b2bd41cea0010dcc6536a7", "HairpinMode": false, "Networks": { "bridge": { "MacAddress": "", "IPAddress": "", "IPPrefixLen": 0, "NetworkID": "ab66fbf5cc1033dd92f16bffbd1eca0d069d9cde96d817964845f186a34e0f7d", "IPv6Gateway": "", "Gateway": "", "GlobalIPv6PrefixLen": 0, "EndpointID": "", "GlobalIPv6Address": "" } }, "Ports": [ ], "Bridge": "", "MacAddress": "", "IPv6Gateway": "", "IPPrefixLen": 0, "IPAddress": "", "EndpointID": "", "LinkLocalIPv6PrefixLen": 0, "Gateway": "", "GlobalIPv6PrefixLen": 0, "SandboxKey": "\/var\/run\/docker\/netns\/49e92ff6ac73", "GlobalIPv6Address": "" }, "MountLabel": "", "HostsPath": "\/opt\/docker\/containers\/5a2febdeb66d3f12500e337359a3cf8c88bbef628554fa5242d23bc8012b3efa\/hosts", "LogPath": "\/opt\/docker\/containers\/5a2febdeb66d3f12500e337359a3cf8c88bbef628554fa5242d23bc8012b3efa\/5a2febdeb66d3f12500e337359a3cf8c88bbef628554fa5242d23bc8012b3efa-json.log", "RestartCount": 16, "Config": { "AttachStdout": false, "Entrypoint": [ "\/init" ], "Labels": { "maintainer": "Emby LLC <apps@emby.media>" }, "User": "", "Tty": false, "AttachStdin": false, "AttachStderr": false, "OpenStdin": false, "Volumes": { "\/config": [ ] }, "Image": "emby\/embyserver_arm64v8:latest", "WorkingDir": "\/", "Hostname": "embyserver", "ExposedPorts": { "8920\/tcp": [ ], "8096\/tcp": [ ], "1900\/udp": [ ], "7359\/udp": [ ] }, "Domainname": "", "Env": [ "UID=0", "GID=0", "GIDLIST=100", "PATH=\/usr\/local\/sbin:\/usr\/local\/bin:\/usr\/sbin:\/usr\/bin:\/sbin:\/bin", "LANG=en_US.UTF-8", "HOME=\/tmp", "AMDGPU_IDS=\/share\/libdrm\/amdgpu.ids", "FONTCONFIG_PATH=\/etc\/fonts", "LD_LIBRARY_PATH=\/lib:\/system", "LIBVA_DRIVERS_PATH=\/lib\/dri", "OCL_ICD_VENDORS=\/etc\/OpenCL\/vendors", "PCI_IDS_PATH=\/share\/hwdata\/pci.ids", "SSL_CERT_FILE=\/etc\/ssl\/certs\/ca-certificates.crt", "NVIDIA_VISIBLE_DEVICES=all", "NVIDIA_DRIVER_CAPABILITIES=compute,video,utility", "XDG_CACHE_HOME=\/config\/cache" ], "StdinOnce": false }, "Mounts": [ { "Type": "bind", "Source": "\/mnt\/sda2\/Películas", "Mode": "", "Destination": "\/Movies", "RW": true, "Propagation": "rprivate" }, { "Type": "bind", "Source": "\/mnt\/sda2\/Series", "Mode": "", "Destination": "\/TVShows", "RW": true, "Propagation": "rprivate" }, { "Name": "a7346b98288bb1061340c408617f21a498bd03840d7f9f87bbea3cf7f78cb383", "Type": "volume", "Source": "\/opt\/docker\/volumes\/a7346b98288bb1061340c408617f21a498bd03840d7f9f87bbea3cf7f78cb383\/_data", "RW": true, "Mode": "", "Destination": "\/config", "Driver": "local", "Propagation": "" } ], "Id": "5a2febdeb66d3f12500e337359a3cf8c88bbef628554fa5242d23bc8012b3efa", "Platform": "linux", "HostConfig": { "PidMode": "", "MemorySwap": 0, "ConsoleSize": [ 0, 0 ], "IOMaximumIOps": 0, "DnsOptions": [ ], "CpuPeriod": 0, "OomScoreAdj": 0, "BlkioWeight": 0, "ShmSize": 67108864, "Privileged": false, "PortBindings": { "8096\/tcp": [ { "HostIp": "", "HostPort": "8096" } ], "8920\/tcp": [ { "HostIp": "", "HostPort": "8920" } ] }, "CpuShares": 0, "NetworkMode": "bridge", "CpuQuota": 0, "DnsSearch": [ ], "NanoCpus": 0, "CpuCount": 0, "Isolation": "", "Cgroup": "", "ContainerIDFile": "", "AutoRemove": false, "UTSMode": "", "VolumeDriver": "", "ReadonlyPaths": [ "\/proc\/bus", "\/proc\/fs", "\/proc\/irq", "\/proc\/sys", "\/proc\/sysrq-trigger" ], "MaskedPaths": [ "\/proc\/asound", "\/proc\/acpi", "\/proc\/kcore", "\/proc\/keys", "\/proc\/latency_stats", "\/proc\/timer_list", "\/proc\/timer_stats", "\/proc\/sched_debug", "\/proc\/scsi", "\/sys\/firmware", "\/sys\/devices\/virtual\/powercap" ], "CpuRealtimePeriod": 0, "IOMaximumBandwidth": 0, "CpuPercent": 0, "Binds": [ "\/mnt\/sda2\/Películas:\/Movies", "\/mnt\/sda2\/Series:\/TVShows" ], "MemoryReservation": 0, "Dns": [ ], "RestartPolicy": { "Name": "unless-stopped", "MaximumRetryCount": 0 }, "PublishAllPorts": false, "CpusetMems": "", "CpusetCpus": "", "CpuRealtimeRuntime": 0, "ReadonlyRootfs": false, "UsernsMode": "", "Memory": 0, "CgroupParent": "", "IpcMode": "private", "CgroupnsMode": "private", "LogConfig": { "Config": [ ], "Type": "json-file" }, "Runtime": "runc" }, "GraphDriver": { "Data": { "MergedDir": "\/opt\/docker\/fuse-overlayfs\/fa86c66629927bc27b278e5065571ab8ea3bb4b6382236d065e8f54e3bf2ff2a\/merged", "WorkDir": "\/opt\/docker\/fuse-overlayfs\/fa86c66629927bc27b278e5065571ab8ea3bb4b6382236d065e8f54e3bf2ff2a\/work", "UpperDir": "\/opt\/docker\/fuse-overlayfs\/fa86c66629927bc27b278e5065571ab8ea3bb4b6382236d065e8f54e3bf2ff2a\/diff", "LowerDir": "\/opt\/docker\/fuse-overlayfs\/fa86c66629927bc27b278e5065571ab8ea3bb4b6382236d065e8f54e3bf2ff2a-init\/diff:\/opt\/docker\/fuse-overlayfs\/dd918ae641c73b405161c92f0cbae83de1177307719a3ec74890e4f31fd53df5\/diff:\/opt\/docker\/fuse-overlayfs\/df89f53abcbc926c4d7306cc546ef4cc1b72a71ad26b346e5a0e152849f784cc\/diff:\/opt\/docker\/fuse-overlayfs\/481e8ebb0e678e49774767a93eeb563c906bf426a3f0ee9bc5f1220a73f16f83\/diff:\/opt\/docker\/fuse-overlayfs\/20d9388b3cc84a778a7ee2e930d12f3bdc347b71a1cb5f739c0ad152abeeed90\/diff" }, "Name": "fuse-overlayfs" }, "State": { "Pid": 0, "FinishedAt": "2024-03-06T08:18:42.360006793Z", "StartedAt": "2024-03-06T08:18:41.151739327Z", "Error": "", "Running": true, "Paused": false, "OOMKilled": false, "Status": "restarting", "ExitCode": 126, "Restarting": true, "Dead": false }, "Driver": "fuse-overlayfs", "Name": "\/embyserver", "Args": [ ], "HostnamePath": "\/opt\/docker\/containers\/5a2febdeb66d3f12500e337359a3cf8c88bbef628554fa5242d23bc8012b3efa\/hostname", "Created": "2024-03-06T07:20:36.480898553Z", "AppArmorProfile": "", "Image": "sha256:6909a32f1120214399c6013462c0ae43edc21ef84344337e2229613615d96418" }
Luke 42244 Posted March 6, 2024 Posted March 6, 2024 Hi there, please attach the emby server log from when the problem occurred: How to Report a Problem Thanks.
Miles28 3 Posted March 6, 2024 Author Posted March 6, 2024 The only log I've been able to find is this one. Emby server is not running. I haven't been able to enter the web interface. 5a2febdeb66d3f12500e337359a3cf8c88bbef628554fa5242d23bc8012b3efa-json.log
Miles28 3 Posted March 6, 2024 Author Posted March 6, 2024 (edited) I have tried with other images, helllo-world, jellifyn, Ubuntu, and all of them run ok. This have to be something related with the last update of docker family packages in OpenWRT and Emby Server image. Everytime I start the Emby Server container, docker network interface links down and restarts again.. Edited March 6, 2024 by Miles28
adminExitium 356 Posted March 6, 2024 Posted March 6, 2024 Can you try running the LSIO emby docker image too? Will help to figure out whether it's a software issue or image issue.
adminExitium 356 Posted March 6, 2024 Posted March 6, 2024 (edited) So something image specific and not the package itself. The LSIO build file is available here: https://github.com/linuxserver/docker-emby so it should be easy enough for @Luketo figure out what is different. Edited March 6, 2024 by adminExitium 1
Luke 42244 Posted March 7, 2024 Posted March 7, 2024 19 hours ago, Miles28 said: The only log I've been able to find is this one. Emby server is not running. I haven't been able to enter the web interface. 5a2febdeb66d3f12500e337359a3cf8c88bbef628554fa5242d23bc8012b3efa-json.log 19.36 kB · 1 download Did you look in the server data folder for log files? Emby Server Data Folder
Miles28 3 Posted March 7, 2024 Author Posted March 7, 2024 2 hours ago, Luke said: Did you look in the server data folder for log files? Emby Server Data Folder No, I couldn't find it. As I mentioned, the only record I could locate was this one: {"log":"importas: fatal: unable to exec export: Not supported\n","stream":"stderr","time":"2024-03-06T08:52:31.036251332Z"} But if you need it, I can try to deploy again the official Emby Server image later.
Luke 42244 Posted March 7, 2024 Posted March 7, 2024 12 hours ago, Miles28 said: No, I couldn't find it. As I mentioned, the only record I could locate was this one: {"log":"importas: fatal: unable to exec export: Not supported\n","stream":"stderr","time":"2024-03-06T08:52:31.036251332Z"} But if you need it, I can try to deploy again the official Emby Server image later. Hi, yes that would be great, thanks.
