heffeque 78 Posted March 5, 2024 Posted March 5, 2024 On 3/1/2024 at 11:11 PM, heffeque said: (Hopefully the "Fix playback errors when transcoding on older LG TV's" will work, will let you know). Nope, when subs are present, transcoding is needed and it's still not working correctly on LG TVs. It just hangs, even on newer LG TVs Oh well.
Luke 42234 Posted March 6, 2024 Posted March 6, 2024 @heffeque Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
heffeque 78 Posted April 24, 2024 Author Posted April 24, 2024 (edited) This fixed it: For some reason I had subtitle on the fly extraction disabled. In theory subs should still work with it disabled (by using transcoding), but anyway... Once enabled, subs are working on the LG app. You can close it. Edited April 24, 2024 by heffeque 1
