simpz 2 Posted March 5, 2024 Posted March 5, 2024 Hi I have an issue where when the container I have running TVHeadend is restarted the EmbyServer process goes to 100% CPU and stays there. If Emby is then restarted it goes back to normal largely idle. I have TVHeadend setup as a live TV source in Emby and seems to work fine. 1433350 emby 20 0 5266664 323020 54652 S 101.0 0.5 4:29.22 EmbyServer The TVHeadend and Emby Server run on the same Debian 12 machine. I see nothing in the logs of either subsystem. Anyone seen this before?
Luke 42241 Posted March 6, 2024 Posted March 6, 2024 Hi there, please attach the emby server log from when the problem occurred. Thanks.
Luke 42241 Posted March 7, 2024 Posted March 7, 2024 HI, if you wait until the cpu usage calms down, then run the refresh guide scheduled task, does it go back up again?
simpz 2 Posted March 7, 2024 Author Posted March 7, 2024 The CPU never calms down that I can see, it stays at 100% a day after the TVHeadend was restarted.
Luke 42241 Posted March 7, 2024 Posted March 7, 2024 If you remove the TVH plugin, how do things compare?
simpz 2 Posted March 8, 2024 Author Posted March 8, 2024 It only happens when the Live TV TVH Plugin is enabled. Otherwise it doesn't happen. 1
simpz 2 Posted March 9, 2024 Author Posted March 9, 2024 A bit more analysis, it seems to maybe happen approx every once out of 2-3 times the TVHeadend is restarted. So not quite every times, just 33-50% of the time.
simpz 2 Posted March 14, 2024 Author Posted March 14, 2024 Not sure if there is any more I can give you here. Maybe I could attached an strace to embyserver when it's spinning it's wheels?
Luke 42241 Posted March 14, 2024 Posted March 14, 2024 9 hours ago, simpz said: Not sure if there is any more I can give you here. Maybe I could attached an strace to embyserver when it's spinning it's wheels? Sure.
simpz 2 Posted March 15, 2024 Author Posted March 15, 2024 Okay the strace is interesting, and simple. From a threaded top: 2772754 emby 20 0 5527680 495148 92472 S 94.1 0.8 161:02.43 EmbyServer 2991061 emby 20 0 5527680 495148 92472 R 94.1 0.8 158:50.23 .NET ThreadPool , the 100% CPU is actually a ".NET ThreadPool" thread. Digging further (attached in an strace to this thread), you get a fast continuous stream of (50000-70000 per second!): recvmsg(236, {msg_name=NULL, msg_namelen=0, msg_iov=[{iov_base="", iov_len=1024}], msg_iovlen=1, msg_controllen=0, msg_flags=0}, 0) = 0 lsof on this pid we see this: Quote EmbyServe 2772754 emby 236u IPv4 10394798 0t0 TCP localhost:54552->servername.lan:9982 (CLOSE_WAIT) ,where "servername" is my server name, this is the same box running Emby as the TVHeadend Container. So the issue seems to be that the process is stuck waiting for a CLOSE_WAIT from the socket to the original TVHeadend Container (this has been restarted and is listening again on this port 9982). This CLOSE_WAIT is never likely to happen as the service (process) that Emby was opened to has now gone (container was torn down and brought back up again). Now it's possible things aren't so simple, as container networking has a lot of firewall manipulation for port forwarding ports, so maybe this old connection is just getting all it's packets dropped silently. But in any case, Emby probably shouldn't wait forever for a CLOSE_WAIT here and especially not in a tight loop! Thoughts.... 1
simpz 2 Posted March 22, 2024 Author Posted March 22, 2024 Any thoughts on this? Looks pretty clear cut to me...
Luke 42241 Posted March 25, 2024 Posted March 25, 2024 Hi, for testing purposes, what if you remove the TVH plugin from Emby Server, and then import the TVH content into Emby Server using m3u? TVH has an m3u output feature so you could just use that without the plugin. It would be helpful to see how that compares. Thanks.
simpz 2 Posted March 26, 2024 Author Posted March 26, 2024 curl -o channels.m3u -u admin:password http://servername:9981/playlist/channels.m3u I can create a channel.m3u but Emby doesn't like this type "No compatible streams are currently available. Please try again later or contact your system administrator for details."
Luke 42241 Posted March 27, 2024 Posted March 27, 2024 12 hours ago, simpz said: curl -o channels.m3u -u admin:password http://servername:9981/playlist/channels.m3u I can create a channel.m3u but Emby doesn't like this type "No compatible streams are currently available. Please try again later or contact your system administrator for details." HI, can you please attach the emby server log? How to Report a Problem Thanks.
Luke 42241 Posted April 9, 2024 Posted April 9, 2024 On 4/1/2024 at 4:53 AM, simpz said: I sent that to you privately I think HI, regarding m3u usage, please see if this helps: Thanks.
simpz 2 Posted April 11, 2024 Author Posted April 11, 2024 So my channels.m3u file look like this and works with VLC. #EXTM3U #EXTINF:-1 logo="http://admin:password@server.lan:9981/imagecache/44" tvg-id="1879fe7c8731a05a75a73ea7dd8ad2c8" tvg-chno="1",BBC ONE EastHD http://admin:password@server.lan:9981/stream/channelid/2097051928 #EXTINF:-1 logo="http://admin:password@server.lan:9981/imagecache/45" tvg-id="ae1a5e99bf2b858fd0395d122abd24cf" tvg-chno="2",BBC TWO HD http://admin:password@server.lan:9981/stream/channelid/425597614 Where "password" is the real admin password of my tvheadend service. The log file shows: 2024-04-10 08:22:47.990 Info HttpClient: GET http://admin:password@host1:9981/x_path1_x/x_path2_x/x_path3_x 2024-04-10 08:22:47.990 Info HttpClient: Found userInfo in url: admin:password ... url: http://admin:password@host1:9981/x_path1_x/x_path2_x/x_path3_x 2024-04-10 08:22:47.991 Info HttpClient: Http response 401 from http://admin:password@host1:9981/x_path1_x/x_path2_x/x_path3_x after 1ms. Headers Server=HTS/tvheadend, Cache-Control=no-cache, WWW-Authenticate=Digest realm="tvheadend", qop=auth, algorithm=SHA-512-256, nonce="OBFUSCATE", opaque="OBFUSCATE" Digest realm="tvheadend", qop=auth, nonce="OBFUSCATE", opaque="OBFUSCATE", Connection=close Where OBFUSCATE is a secret hash I have obfuscated, and the password is shown as the plain text matching the above in the URLs from channels.m3u. However the "@host1:9981/x_path1_x/x_path2_x etc" doesn't match anything passed I can see. I could add the tvheadend container systemd unit file: ExecStartPost=/bin/systemctl restart emby-server.service But of course this doesn't help you address what is clearly a bug in Emby Server (or possibly (even likely) in the .NET framework), that if a connection drops out to the TvHeadend backend and just drops packets it waits for ever on CLOSE_WAIT. Seems like a very similar issue in dotnet but appears resolved? https://github.com/dotnet/runtime/issues/36293
Q-Droid 1011 Posted April 11, 2024 Posted April 11, 2024 This works if you create a no-auth account in TVHeadend then credentials are not needed for the m3u streams. If you're worried about open access to TVH you can use source IP restrictions to limit account access.
simpz 2 Posted April 12, 2024 Author Posted April 12, 2024 The no-auth account has indeed allowed M3U playlist to work and I can stream Live TV. The 100% CPU issue doesn't seem to occur on restarting the TVHeadend container. It seems pretty obvious why this might, with an M3U playlist I'd guess there is no connection being made until a stream is started. However, with a TVHeadend backend there is a persistent connection from Emby to TVHeadend (for TV Guide etc). So the issue with a connection not being closed properly an looping on close_wait will pretty much always occur with the TVHeadend backend. Did you look at the .NET Framework bug I posted that pretty much fits this? Is the version of the .NET framework you use, one that likely has this issue resolved or not?
