ernstgot 17 Posted November 4, 2014 Posted November 4, 2014 I have auto organize turned on and have a small problem. I use an RSS feed to download a torrent and its in Xvid format but before the file is finished downloading it moves said file to the season folder and I can't play the video because its not complete or so it looks. If I go in to the season folder and delete the file then auto organize copies the file once again and it will play. Any solution would be great.
Luke 42184 Posted November 4, 2014 Posted November 4, 2014 this isn't supported right now. right now you need to make sure the files are complete before exposing them to auto-organize.
LiquidFX 144 Posted November 4, 2014 Posted November 4, 2014 You can use media center master to handle the file, then have it moved to a folder that MB scans
pmac 143 Posted November 5, 2014 Posted November 5, 2014 I set my rss downloader to keep files that are currently being downloaded in an "incomplete" folder, and once the download is finished, it moves them to a "complete" folder, which Auto-Organize watches. I was having the same problem as you, and found this fixed the problem perfectly for me. Also keeps my torrents more organized. 2
