Friends 2 Posted March 4, 2024 Posted March 4, 2024 I can connect to the Emby server on every device using the same credentials accept the Fire TV. I attempt to login with Emby connect and the pin gets confirmed at https://emby.media/pin.html then nothing. I click next on the FireTV and nothing, sometimes I click next and it takes me right back to the screen before giving me the pin. Sometimes it shows me the server, I click on that and then it takes me back to the connect with connect again.
ebr 16307 Posted March 4, 2024 Posted March 4, 2024 Hi. Are you trying to connect with https or just plain http? If https, Amazon devices are quite strict about certs. Are you sure yours is trusted?
