vfducky 4 Posted March 2, 2024 Posted March 2, 2024 After update server to 4.8.1, TV-Channals don't play any more. Server on Debian 12. ... 2024-03-02 13:44:24.362 Info App: ProcessRun 'StreamTranscode c52597': Stopping ffmpeg process with q command for /var/lib/emby/transcoding-tem p/7F345D/7F345D_0.ts 2024-03-02 13:44:24.438 Info App: ProcessRun 'StreamTranscode c52597': Stopping ffmpeg process with q command for /var/lib/emby/transcoding-tem p/7F345D/7F345D_0.ts 2024-03-02 13:44:24.441 Info App: AppendExtraLogData - Read graph file: /var/lib/emby/logs/ffmpeg-transcode-c5259767-aa6c-45eb-9323-47459ca2259 e_1graph.txt 2024-03-02 13:44:24.441 Warn App: AppendExtraLogData: Unable read graph output file: /var/lib/emby/logs/ffmpeg-transcode-c5259767-aa6c-45eb-932 3-47459ca2259e_1graph.txt 2024-03-02 13:44:24.442 Info App: ProcessRun 'StreamTranscode c52597' Process exited with code 137 - Failed ... error in "ffmpeg-transcode-c5259767-aa6c-45eb-9323-47459ca2259e_1graph.txt" ... 13:44:14.765 ffmpeg version 5.1-emby_2023_06_25 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC 13:44:14.765 built with gcc 10.3.0 (crosstool-NG 1.25.0) 13:44:14.765 Execution Date: 2024-03-02 13:44:14 13:44:14.769 [AVHWDeviceContext @ 0x1459380] libva: /opt/emby-server/extra/lib/dri/iHD_drv_video.so init failed 13:44:15.258 [http @ 0x1486e40] Will reconnect at 1073 in 0 second(s), error=End of file. 13:44:15.720 [http @ 0x1486e40] Will reconnect at 0 in 1 second(s), error=End of file. 13:44:17.145 [http @ 0x1486e40] Will reconnect at 0 in 3 second(s), error=End of file. 13:44:20.573 [http @ 0x1486e40] Will reconnect at 0 in 7 second(s), error=End of file. Before update all was working fine (((
Luke 42244 Posted March 6, 2024 Posted March 6, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
vfducky 4 Posted March 24, 2024 Author Posted March 24, 2024 Hi Sorry, was very busy. I found same problem topik Any new version of Emby server don't play tv stream. I have made downgrade to version 4.7.11. It very sad because TV need :(
Luke 42244 Posted March 25, 2024 Posted March 25, 2024 @vfducky Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
vfducky 4 Posted March 28, 2024 Author Posted March 28, 2024 TV still don't working with message "Don't have compatible sream" embyserver-63847213451.txt embyserver.txt ffmpeg-transcode-66e22917-dfe5-4876-a6f7-dfd557c8ef7e_1.txt ffmpeg-transcode-8754bade-1df4-4284-a9af-50431e26ddcd_1.txt ffmpeg-transcode-a43d20c8-d74f-4f34-beca-ed5b84ca875f_1.txt ffmpeg-transcode-b299c605-3b53-4b88-8c90-2fd5b4fe6df8_1.txt ffmpeg-transcode-e73d8dac-ebe9-445c-9d80-1430e0a14841_1.txt ffmpeg-transcode-e215c9b1-8903-4353-927f-8f58a3f6afab_1.txt ffmpeg-transcode-f344004d-9d11-482a-a64f-3c5be0e151e9_1.txt ffmpeg-transcode-eec59c99-032b-413b-a593-e9ba12120412_1.txt hardware_detection-63847213459.txt readme.txt
Luke 42244 Posted March 28, 2024 Posted March 28, 2024 What do you get if you put this url into a browser: http://s08.wsbof.com:8090/s/bcf8042b/ntv.m3u8
vfducky 4 Posted March 28, 2024 Author Posted March 28, 2024 Open in browser get download "ntv.m3u8" file
vfducky 4 Posted March 28, 2024 Author Posted March 28, 2024 Open link in VLC get play chennel. Link work everywhere, exclude Emby
Luke 42244 Posted March 28, 2024 Posted March 28, 2024 1 hour ago, vfducky said: Open in browser get download "ntv.m3u8" file And what's inside that file?
vfducky 4 Posted March 28, 2024 Author Posted March 28, 2024 Inside have few urls of channel stream. I have said, it working in Emby 8.3 and any IPTV or Media Player program but not in Emby 8.4. I think something wrong with ffmpeg.
vfducky 4 Posted May 21, 2024 Author Posted May 21, 2024 (edited) Hi I periodically check new versions of the server, but the TV still doesn’t work. I still use the old version of the server. Shouldn't we expect a fix? Edited May 21, 2024 by vfducky
Luke 42244 Posted May 22, 2024 Posted May 22, 2024 If you can help with this then hopefully we'll have a fix soon: Thanks.
