Luke 42242 Posted January 7, 2025 Posted January 7, 2025 On 12/28/2024 at 2:51 PM, CaptRodwell said: Yes. I think it's happening on the client as I've seen it happen when the client is offline. OK we'll try to chase this down. Thanks.
Nathanial 1 Posted January 24, 2025 Posted January 24, 2025 I am having this same issue downloaded 5or6 episodes of a show at home it said they were downloaded when got to my destination opened up the app my downloads were no longer there 1
Kigeki 10 Posted February 23, 2025 Posted February 23, 2025 Same issue here. Updating to 4.9.0.38 did not make any difference. client 3.4.36 - Android 15. Sometimes downloads start, but then i get several episodes missing forever in "ready for download" state. Basically the same symptoms as other people described in this thread.
sa2000 697 Posted February 24, 2025 Posted February 24, 2025 22 hours ago, Kigeki said: Sometimes downloads start, but then i get several episodes missing forever in "ready for download" state. Basically the same symptoms as other people described in this thread. "Ready for download" state is different from downloaded but disappearing after that. Is the Emby for Android app running and connected to the network ? What settings do you have for downloads on the Emby for Android app settings? When a download is requested, Emby Server would start convesion and then wait for the Emby app to download. Could we a look at specific example. You can enable logging on the Emby for Android app in app settings and then try to reproduce the problem where the download gets to the state of ready to download but not completing or starting the download and then get the emby server logs (embyserver and ffmpeg logs) and the Emby for Android logs and screenshots showing the download status on the server settings and the Emby for Android
Luke 42242 Posted March 20, 2025 Posted March 20, 2025 On 2/24/2025 at 10:19 AM, sa2000 said: "Ready for download" state is different from downloaded but disappearing after that. Is the Emby for Android app running and connected to the network ? What settings do you have for downloads on the Emby for Android app settings? When a download is requested, Emby Server would start convesion and then wait for the Emby app to download. Could we a look at specific example. You can enable logging on the Emby for Android app in app settings and then try to reproduce the problem where the download gets to the state of ready to download but not completing or starting the download and then get the emby server logs (embyserver and ffmpeg logs) and the Emby for Android logs and screenshots showing the download status on the server settings and the Emby for Android @Kigeki?
Kigeki 10 Posted March 20, 2025 Posted March 20, 2025 2 hours ago, Luke said: @Kigeki? Hi, Sorry for the delayed response. I've just tried to reproduce the issue and everything worked surprisingly well. I've switched to 4.9.0.42-beta since then though (client is still on the same version). But last time, when I wrote my previous message, it was a frustrating experience. I was preparing for travel and wanted to download several series and it did not want to start, after the conversion had been done. The same behavior was observed on my wife's phone (apple). After poking around, deleting caches, deleting download queues, (and probably that is when I also switched to beta) I was able to download most of what I needed. Several episodes were still missing, but that was good enough. I've just started several larger batches of downloads with conversions and will update here if it hangs. 2
Kigeki 10 Posted March 21, 2025 Posted March 21, 2025 (edited) Unfortunately, I was able to reproduce it. Here is the details: relevant android app logs: Fri Mar 21 06:17:19 GMT+01:00 2025 AppSyncWorker: Start executing job. Fri Mar 21 06:17:19 GMT+01:00 2025 CameraUploadWorker: Start executing job. Fri Mar 21 06:17:19 GMT+01:00 2025 Found 0 server(s) for camera upload Fri Mar 21 06:17:19 GMT+01:00 2025 CameraUploadWorker: Exit SUCCESS Fri Mar 21 06:17:19 GMT+01:00 2025 ServerSync: Starting sync for server: 5456f9b6c26446df99444e9e7f629a74 'Caspar' Fri Mar 21 06:17:19 GMT+01:00 2025 Getting response stream from http://192.168.200.33:8096/emby/system/info/public?format=json Fri Mar 21 06:17:19 GMT+01:00 2025 Canceling requests with tag determineServerUrlTag-5456f9b6c26446df99444e9e7f629a74 Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: Begin checkLocalFileExistence Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: Begin reportOfflineActions Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: Begin getNewMedia Fri Mar 21 06:17:19 GMT+01:00 2025 Getting response stream from http://192.168.200.33:8096/emby/Sync/Items/Ready?TargetId=0bd25342be9dda37 Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: getReadySyncItems returned 2 items Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: Begin getNewItem Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: getLibraryItem found existing item Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: Begin getNewItem Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: getLibraryItem found existing item Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: Begin syncData Fri Mar 21 06:17:19 GMT+01:00 2025 Getting response stream from http://192.168.200.33:8096/emby/Sync/data Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: Exit syncData Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: Begin afterSyncData Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: afterSyncData found 0 item(s) to remove Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: afterSyncData found 0 empty container item(s) Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: Exit afterSyncData Fri Mar 21 06:17:19 GMT+01:00 2025 AppSyncWorker: Exit SUCCESS server side logs for the same event: 2025-03-21 06:17:19.013 Info SyncService-0HNB7UN934IH3:00000003: http/1.1 POST http://192.168.200.33:8096/emby/Sync/data. Source Ip: 192.168.200.44, UserAgent: okhttp/4.12.0 2025-03-21 06:17:19.045 Info SyncService-0HNB7UN934IH3:00000003: http/1.1 Response 200 to 192.168.200.44. Time: 32ms. POST http://192.168.200.33:8096/emby/Sync/data Out of 3 different tv-shows, only 2 random episodes from 2 shows are stuck. It does not seem these logs highlight any obvious issues other than the fact that android app thinks that these 2 items already exist while they clearly don't `getLibraryItem found existing item` Please see the attached archive for full logs (not sure why android logs start from 4am today though, I enabled them much earlier, but this morning's sync event is there at least). Screenshots: Spoiler debug.zip Edited March 21, 2025 by Kigeki
sa2000 697 Posted March 21, 2025 Posted March 21, 2025 (edited) Thanks for the logs and screenshots I can see that for the two download jobs there were no transfer requests TRIGUN STAMPEDE - S01E01 Download job #514 Converted at 2025-03-21 02:05:59.982 Arcane - S02E07 Download job #511 Converted at 2025-03-21 01:47:38.317 I would expect to see these requests from the android app POST /emby/Sync/JobItems/511/Transferred POST /emby/Sync/JobItems/514/Transferred after this request POST /emby/Sync/data As you indicated in the android app log - we have these log lines Fri Mar 21 06:17:19 GMT+01:00 2025 Getting response stream from http://ip:8096/emby/Sync/Items/Ready?TargetId=0bd25342be9dda37 Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: getReadySyncItems returned 2 items Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: Begin getNewItem Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: getLibraryItem found existing item Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: Begin getNewItem Fri Mar 21 06:17:19 GMT+01:00 2025 MediaSync: getLibraryItem found existing item I am not sure if "found existing item" is referring to the Pixel 9 Pro already downloaded items If it is reporoducible easily, would like to see a tcpdump of the requests and responses between the Pixel and the emby server. Are you able to do that and get me a zipped pcap file to go with new set of logs with debug logging enabled on the server and android and details of what did not transfer. Could you try the latest beta of the Emby for Android app? I see you are running on 3.4.36. See this post for latest Emby for Android beta Please send the zipped pcap and raw logs zip by private message Edited March 21, 2025 by sa2000
Kigeki 10 Posted March 21, 2025 Posted March 21, 2025 @sa2000, It seems like the android app regularly retries syncing these 2 items so it should be easy to capture these sessions. I will setup a packet capture now and send the dump to you when it is ready. 1
sa2000 697 Posted March 21, 2025 Posted March 21, 2025 (edited) Thanks - and please enable debug logging on the server as well beforehand - in Server Settings > Logs > Settings and get me zipped copy of the raw logs folder with the android debug log and zipped pcap Thank You Edited March 21, 2025 by sa2000 1
sa2000 697 Posted March 21, 2025 Posted March 21, 2025 Thanks @Kigekifor the pcap and the logs. It looks to me like an Android app issue becuase the Emby Server has indicated to the app that there are two ready to transfer "Arcane (2021) - S02E07" and "TRIGUN STAMPEDE (2023) - S01E01" These were returned in the 2 items list in the response to "GET /emby/Sync/Items/Ready" and also later on when specifically requesting info about the download transfer jobs Could you try the latest beta app 3.4.48 ?
Kigeki 10 Posted March 21, 2025 Posted March 21, 2025 I've installed 3.4.48 and cleared the cache but it did not fix the issue. Upon start the behavior is still the same with the same lines in the app log as in the previous snippets.
sa2000 697 Posted March 23, 2025 Posted March 23, 2025 On 21/03/2025 at 23:47, Kigeki said: I've installed 3.4.48 and cleared the cache but it did not fix the issue. Upon start the behavior is still the same with the same lines in the app log as in the previous snippets. Thanks for trying. I presume the issue does not arise for alll season/series downloads - is that correct? Would you be able to reproduce the issue on a series or season that was not attempted to be downloaded before ? To see if we can get pcap and debug logs from both server and android app covering whole period from first start of downloads until the issue arises. I will try to do some season downloads to see if it happens to me. Was there a storage shortage issue at any time on the pixel during the downloads? The specific 2 files are not big Would you happen to have logs going back to when the first downloads were initiated for Arcane and TRIGUN STAMPEDE? What mkv / ass files etc exist below the /transcode folder in paths like these /transcode/65/514/ /transcode/64/511/ The 64 and 65 are download jobs identifiers and the 514 and 511 would be specific episode item job id's
Kigeki 10 Posted March 23, 2025 Posted March 23, 2025 Hey @sa2000, Please see my answers inline: Quote I presume the issue does not arise for alll season/series downloads - is that correct? Correct, it happens quite randomly. As you could see in one case only the first episode failed to download, and in the other - 7th out of total 9. Everything else, as well as other series I tried downloading finished successfully. Quote Would you be able to reproduce the issue on a series or season that was not attempted to be downloaded before ? To see if we can get pcap and debug logs from both server and android app covering whole period from first start of downloads until the issue arises. I might try at some point, but cant promise. All this is very time consuming, sorry. Quote Was there a storage shortage issue at any time on the pixel during the downloads? The specific 2 files are not big Definitely not. More than 100GiB was available at all times. The fact that all other episodes downloaded successfully confirms this. Quote Would you happen to have logs going back to when the first downloads were initiated for Arcane and TRIGUN STAMPEDE? Only the server logs without debug. I will dm you the full version. Short version here: $ grep -E '/(510|511|512)/' emby/logs/embyserver-63878192764.txt | cut -c-250 2025-03-21 01:42:15.862 Info VideoEncoder: ProcessRun 'Encoding 11f1a6' Execute: /app/emby/bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-11f1a69b-630e-4e12-bee4-b27567e5e2f1_1graph.txt" -copyts -start_at_zero -init 2025-03-21 01:47:38.258 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /app/emby/bin/ffprobe -i file:"/transcode/64/510/11f1a69b-630e-4e12-bee4-b27567e5e2f1.mkv" -threads 0 -v info -print_format json -show_streams -show_format -show_data 2025-03-21 01:47:38.317 Info VideoEncoder: ProcessRun 'Encoding 814967' Execute: /app/emby/bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-81496766-fd46-444e-b6f5-365937e962c2_1graph.txt" -copyts -start_at_zero -init 2025-03-21 01:50:12.128 Info SyncService-0HNB7UN934IF0:00000003: http/1.1 POST http:////192.168.200.33:8096/emby/Sync/JobItems/510/Transferred. Source Ip: 192.168.200.44, UserAgent: okhttp/4.12.0 2025-03-21 01:50:12.141 Info SyncService-0HNB7UN934IF0:00000003: http/1.1 Response 204 to 192.168.200.44. Time: 13ms. POST http:////192.168.200.33:8096/emby/Sync/JobItems/510/Transferred 2025-03-21 01:53:31.914 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /app/emby/bin/ffprobe -i file:"/transcode/64/511/81496766-fd46-444e-b6f5-365937e962c2.mkv" -threads 0 -v info -print_format json -show_streams -show_format -show_data 2025-03-21 01:53:31.959 Info VideoEncoder: ProcessRun 'Encoding 1e56f9' Execute: /app/emby/bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-1e56f994-b29a-40bd-9b8d-c2aac21dedd8_1graph.txt" -copyts -start_at_zero -init 2025-03-21 01:59:09.508 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /app/emby/bin/ffprobe -i file:"/transcode/64/512/1e56f994-b29a-40bd-9b8d-c2aac21dedd8.mkv" -threads 0 -v info -print_format json -show_streams -show_format -show_data 2025-03-21 01:59:14.789 Info SyncService-0HNB7UN934IF7:00000003: http/1.1 POST http:////192.168.200.33:8096/emby/Sync/JobItems/512/Transferred. Source Ip: 192.168.200.44, UserAgent: okhttp/4.12.0 2025-03-21 01:59:14.796 Info SyncService-0HNB7UN934IF7:00000003: http/1.1 Response 204 to 192.168.200.44. Time: 8ms. POST http:////192.168.200.33:8096/emby/Sync/JobItems/512/Transferred As you can see 510 finished transcoding and transferred successfully as well as 512. While 511 finished transcoding and was never downloaded. Quote What mkv / ass files etc exist below the /transcode folder in paths like these Everything is there as expected. I've also downloaded these files to my PC and they seem fine, I can play the video without issues. 17 Mar 21 01:07 /storage/emby_transcoding/64 54 Mar 21 00:47 /storage/emby_transcoding/64/511 291966442 Mar 21 00:53 /storage/emby_transcoding/64/511/81496766-fd46-444e-b6f5-365937e962c2.mkv 17 Mar 21 01:19 /storage/emby_transcoding/65 98 Mar 21 01:07 /storage/emby_transcoding/65/514 258266592 Mar 21 01:07 /storage/emby_transcoding/65/514/344974f4-c4b9-4e55-b748-d1ea60cdb3ed.mkv 52944 Apr 5 2024 /storage/emby_transcoding/65/514/b01a0a3a66ac46f58c30a23c033c12c4.ass 1
sa2000 697 Posted March 24, 2025 Posted March 24, 2025 @Kigeki In Emby App Settings for Downloads on the Pixel, did you make changes to the target location from the default of Internal Storage ? Has it always been the same target location? I have been doing repeated downloads and so far I have not been able to get the issue.
sa2000 697 Posted March 24, 2025 Posted March 24, 2025 15 hours ago, Kigeki said: I will dm you the full version. OK - will wait for those logs plus all the android app logs that may exist.
Kigeki 10 Posted March 24, 2025 Posted March 24, 2025 55 minutes ago, sa2000 said: @Kigeki In Emby App Settings for Downloads on the Pixel, did you make changes to the target location from the default of Internal Storage ? Has it always been the same target location? I played with this setting before, around the time of my initial post, but it did not help and I reverted to "internal storage". All the latest tests were conducted with "internal storage" selected and I did not touch any other download settings. Quote I have been doing repeated downloads and so far I have not been able to get the issue. I’d like to point out that during this latest test, I initiated the download of 3 different TV series, totaling 4 seasons with approximately 10 episodes each—around 40 episodes in total. Transcoding was enabled, and the entire process took about 4 hours to complete (start: 2025-03-20 22:42:00.342, end: 2025-03-21 02:17:58.605). Only 2 episodes got stuck for me, though, so it might just be that you got lucky Taking a blind guess: could it be that Android kills the app (for whatever reason) in the middle of the process, while the app marks episodes as "done" in its internal database before they're actually completed?
sa2000 697 Posted March 24, 2025 Posted March 24, 2025 3 minutes ago, Kigeki said: I played with this setting before, around the time of my initial post, but it did not help and I reverted to "internal storage". I was just thinking if the target location changed during the downloads Are you able to see if there are any downloads on the external storage ?
Kigeki 10 Posted March 24, 2025 Posted March 24, 2025 (edited) 38 minutes ago, sa2000 said: I was just thinking if the target location changed during the downloads Are you able to see if there are any downloads on the external storage ? I'm certain it didn't change. I've just double checked the external Downloads folder to confirm there is no Emby downloads. 2 hours ago, sa2000 said: plus all the android app logs that may exist. They don't, unfortunately, I enabled them the next morning when I was instructed to do so. Edited March 24, 2025 by Kigeki 1
sa2000 697 Posted March 24, 2025 Posted March 24, 2025 @KigekiThanks for all the diagnostics provided. I have not been able to reproduce the issue trying out multiple series downloads. I have now referred the issue with the diagnostics to the development team 1
sa2000 697 Posted March 24, 2025 Posted March 24, 2025 (edited) @KigekiIn my attempt to reproduce the issue, I did 5 TV shows downloads and 3 of them completed ok but 2 were in state of ready to transfer and transferring. I have 50 episodes flagged by the server as ready to transfer but the android app was logging the same log lines as you had in your logs for these 50 episodes I discovered whilst trying to share my android logs through the app that the device was short on storage - i had a pop up So I deleted the download job for the 3 series that completed ok and after that the 50 ready to transfer got redued to 38 So could you please when the problem arises, go to settings on the device and find out how much free space there is at that time on internal storage for the device Edited March 24, 2025 by sa2000 1
sa2000 697 Posted March 25, 2025 Posted March 25, 2025 (edited) @Kigeki An update - after the earlier shortage of storage and then freeing up storage - download transfers resumed but i have ended up now with same situation as your case - with 2 episodes not being downloaded - with over 15Gb free internal storage available. I do not know at this stage, if the earlier transient storage shortage was a factor in leading to the current state Edited March 25, 2025 by sa2000 1
Kigeki 10 Posted March 25, 2025 Posted March 25, 2025 @sa2000I repeated the test overnight. I cleared all download queues, deleted all downloaded episodes from the phone, and added 5 different series to the download queue again. Here is the current state as of this morning: 3 series downloaded completely without issues 1 episode is stuck in 'ready for download' status for Trigun (interestingly, it's S01E01 again) 7 episodes are stuck in 'ready for download' status for Arcane (S02E01-07) There is still plenty of space available. Screenshots: Spoiler 1
sa2000 697 Posted April 9, 2025 Posted April 9, 2025 @KigekiWe have fixed a problem relating to downloads in beta 4.9.0.43 which is for cases when there are loads of episodes being downloaded. I would like to know if with this change, the problem still occurs. Could you repeat the test for series/seasons that have not been downloaded before and if it still arises, please let me get fresh set of debug log files - from both android and the server and screenshots and info on when the downloads were initiated and which episodes remained in ready to transfer state Thanks 1
Kigeki 10 Posted April 11, 2025 Posted April 11, 2025 @sa2000The issue is still reproducible on beta 4.9.0.43. I'll send you the logs in DM shortly. 1
