Mookdog 90 Posted March 2, 2024 Posted March 2, 2024 Hey guys I recently started fooling with rclone & zurg and I am wondering is there a script I can use to make emby automatically scan the particular mounted folder once I drop a new video on there ? I successfully did it with plex using the powershell script but for some reason I am hitting a roadblock trying to get emby to do the same thing Thanks Mook
adminExitium 356 Posted March 2, 2024 Posted March 2, 2024 We are going to need more details of the "roadblock" that you are facing, but in general it's just an API request to scan a particular library or multiple libraries: 1
