MatthiasM 6 Posted March 1, 2024 Posted March 1, 2024 Hi folks I'm an old emby user but bloody new with the Android TV client since I got my NV shield device. However, I recognise a behavior that is different from all other clients that I use and maybe someone can tell me if this is a know missing feature and was already places to a backlog or this is a bug?!? If I navigate to myphoto library there are to kindof folders - the default ones with no specified folder images (no poster.jpg inside the folder itself, the folder images was auto generated by emby) and the other ones which I choose a specified folder images and the poster.jpg is in place. with ios, android, web windows client emby show both tyes of folder image scorrectly and if I switch the server protocol to debug I can see all these requets readin images, enhance them etc. If I do that with the Android TV, only the folders with the poster.jpg in place will be displayed the other, auto generated images are not displayed and a gray placeholder icon is visible instead. Also the log won't any request at the server and it seems the the client even don't send a request to the server to get those images. Can anyone please enlighten me Thanks and best regards Matthias
Luke 42244 Posted March 1, 2024 Posted March 1, 2024 Hi there, can you please show an example? Thanks.
MatthiasM 6 Posted March 1, 2024 Author Posted March 1, 2024 sure @Luke Android TV IOS Windows Chrome Browser Windows emby Theater Android
ebr 16337 Posted March 2, 2024 Posted March 2, 2024 Hi. What is different about the one that does show an image on the TV?
MatthiasM 6 Posted March 3, 2024 Author Posted March 3, 2024 Hi @ebrin that folder I did specify the image by choosing it inside the emby client or placeing the poter.jpg inside that folder. In all the folders with the grey placeholders that didn't be done and emby auto generated the displayed images. It looks like - just my thoughts - that the client don't request that images. With protocol on the emby server turned to debug I can see activity while I navigate trugh the foto folders with the client (windows chrome browser or windows eby theater as example) if I do that with the Android TV client the log show no requests. I don't have enough insider knowledge about how emby works with auto generated images nor where they are stored. For my opinion the server should handle that difference: if a poster.jpg is in place display that - if no poster.jpg is in place read the auto generated one from (??? the temp path) and display it. I hope my description explain the issue clear enough thx Matthias
Luke 42244 Posted March 6, 2024 Posted March 6, 2024 Hi, what version of Emby for Android TV do you have?
MatthiasM 6 Posted March 9, 2024 Author Posted March 9, 2024 Hi @Luke Server Version 4.9.0.8 beta and AndroidTv 2.0.98g 1
