pir8radio 1313 Posted November 3, 2014 Posted November 3, 2014 I've kinda, sorta.... looked around... is there any info on how to create your own channels? I would like to learn what the limitations are and try to make some kind of channel that will allow me to view my IP Camera feeds... Thanks,
Cheesegeezer 3106 Posted November 3, 2014 Posted November 3, 2014 There is a thread here that you may wish to contribute to http://mediabrowser.tv/community/index.php?/topic/11861-creating-pluginschannels/
pir8radio 1313 Posted November 3, 2014 Author Posted November 3, 2014 well..... i guess i didnt look hard enough... thanks!!!
snazy2000 344 Posted November 3, 2014 Posted November 3, 2014 The video bookmark plugin should do what you need 1
Cheesegeezer 3106 Posted November 3, 2014 Posted November 3, 2014 The video bookmark plugin should do what you need Nice
pir8radio 1313 Posted November 4, 2014 Author Posted November 4, 2014 The video bookmark plugin should do what you need OOOOOoooo it does look to do what i want... hopefully i have a format that will work from my cam... sweet, thanks!
snazy2000 344 Posted November 4, 2014 Posted November 4, 2014 OOOOOoooo it does look to do what i want... hopefully i have a format that will work from my cam... sweet, thanks! No problem that is one of the reasons the plugin was created !
Luke 42243 Posted November 4, 2014 Posted November 4, 2014 I will do a blog post for new developers because I think we've picked up a lot of new community members recently who might have interest in contributing. 1
