JunLui 3 Posted March 24, 2024 Author Posted March 24, 2024 On 3/23/2024 at 12:58 PM, Luke said: Hi, what do you mean by flushed? In this screenshot, what does the blue button say (in english)? What happens if you click it? 我现在有一个新的问题,我想要把Windows Emby Server迁移到新的CentOS Emby Server是否能够实现
Junglejim 385 Posted March 24, 2024 Posted March 24, 2024 On your dashboard screenshot your port is (38920) but your trying to connect with (8920), is this correct?
JunLui 3 Posted March 24, 2024 Author Posted March 24, 2024 4分钟前,Junglejim 说: 在仪表板屏幕截图中,您的端口是 (38920),但您尝试连接 (8920),这是正确的吗? 38920是外网映射端口,8920是服务器监听端口 我是在本地网络上直接测试
Junglejim 385 Posted March 24, 2024 Posted March 24, 2024 (edited) 4 minutes ago, JunLui said: 38920是外网映射端口,8920是服务器监听端口 我是在本地网络上直接测试 Ok, It just was the first thing that seemed odd. Edited March 24, 2024 by Junglejim
Junglejim 385 Posted March 24, 2024 Posted March 24, 2024 44 minutes ago, JunLui said: 我现在有一个新的问题,我想要把Windows Emby Server迁移到新的CentOS Emby Server是否能够实现 I wouldn't think migrating from Windows to Linux (CentOS) would be possible, could be wrong. Best to start with a new install in my opinion. 1
JunLui 3 Posted March 24, 2024 Author Posted March 24, 2024 7 minutes ago, Junglejim said: I wouldn't think migrating from Windows to Linux (CentOS) would be possible, could be wrong. Best to start with a new install in my opinion. 但是我的媒体数据高达1TB(光是媒体库就已经有十几个),并且我还有二十多位用户(每位用户的内容并不相同),所以从头开始规划是不可能的| 我刚刚使用备份插件迁移过后,发现还有很多配置需要善后
Junglejim 385 Posted March 24, 2024 Posted March 24, 2024 (edited) 11 minutes ago, JunLui said: 但是我的媒体数据高达1TB(光是媒体库就已经有十几个),并且我还有二十多位用户(每位用户的内容并不相同),所以从头开始规划是不可能的| 我刚刚使用备份插件迁移过后,发现还有很多配置需要善后 Yeah I hear ya, it's a pain! Windows to Linux migration will never work the way you want it to in that situation. The backup plugin is not really designed for that scenario. Edited March 24, 2024 by Junglejim
JunLui 3 Posted March 24, 2024 Author Posted March 24, 2024 2 minutes ago, Junglejim said: 是的,我听到了,在这种情况下很痛苦。在这种情况下,Windows 到 Linux 的迁移将永远无法按照您想要的方式工作。备份插件并不是真正为这种情况而设计的。 又有几个人能考虑到这种极端情况
Junglejim 385 Posted March 24, 2024 Posted March 24, 2024 2 minutes ago, JunLui said: 又有几个人能考虑到这种极端情况 Everybody.. All..
Junglejim 385 Posted March 24, 2024 Posted March 24, 2024 I run Linux, always have. The only Windows PC device I have is my ROG Ally. Plus I have a Xbox but you can't count that. You should have started with Linux...
Happy2Play 9814 Posted March 24, 2024 Posted March 24, 2024 10 hours ago, Junglejim said: I wouldn't think migrating from Windows to Linux (CentOS) would be possible, could be wrong. Not easy as you have to ensure all paths get updated everyhwere. But the concept would be the same cross platform. So you have to ensure every table that contains path get an update. UPDATE "main"."MediaItems" SET "Path" = replace( "Path", 'C:\Users\Media\Desktop\Videos', 'E:\Media' ) WHERE path LIKE 'C:\Users\Media\Desktop\Videos%'; UPDATE "main"."MediaItems" SET "Images" = replace( "Images", 'C:\Users\Media\Desktop\Videos', 'E:\Media' ) WHERE Images LIKE 'C:\Users\Media\Desktop\Videos%'; UPDATE "main"."MediaStreams2" SET "Path" = replace( "Path", 'C:\Users\Media\Desktop\Videos', 'E:\Media' ) WHERE path LIKE 'C:\Users\Media\Desktop\Videos%'; UPDATE "main"."Chapters3" SET "ImagePath" = replace( "ImagePath", 'C:\Users\Media\Desktop\Videos', 'E:\Media' ) WHERE imagepath LIKE 'C:\Users\Media\Desktop\Videos%'; UPDATE "main"."ItemExtradata" SET "Value" = replace( "Value", '"Path":"C:\\Users\\Media\\Desktop\\Videos', '"Path":"E:\\Media' ) WHERE value LIKE '%"Path":"C:\\Users\\Media\\Desktop\\Videos%'; If you filled in Network path on Library setup you will/could need to update in options.xml and itemextradata. But xml is obsolete in new 4.8+ as info becomes database only. *Plugin configs And I am sure I am still missing some.
Luke 42288 Posted April 4, 2024 Posted April 4, 2024 On 3/23/2024 at 1:17 AM, JunLui said: 我现在有一个想法,如果要把Emby接入CDN这个想法可实现吗? 需要进行什么操作有什么限制? HI, have you taken a look at this?
JunLui 3 Posted April 4, 2024 Author Posted April 4, 2024 4分钟前,卢克说: 嗨,你看过这个吗? 看过了,但对我来说并没有什么用 我使用的CDN服务商并不是CloudFlare
