JohnWilburger 0 Posted February 29, 2024 Posted February 29, 2024 I have an IPTV subscription, for which I created a script to convert them into stream files. For this works very well. I have a folder wich has the following strcuture Series ----- UK SERIES ----- DE SERIES ----- AR SERIES ---------- Golf -------------------- Serie 1 -------------------- Serie 2 ---------- Turkish -------------------- Serie 1 -------------------- Serie 2 ---------- Kids -------------------- Serie 1 -------------------- Serie 1 Now the Server recognizes the UK, DE Series but only recognizes the Kids in the ARABIC Series. You see in the Logs (Series 352595, Series 352596) are actually folders and NOT Series (Because they have within the folder Series) From Logs 02-29 10:54:49.936 Debug SqliteItemRepository: GetitemById Folder 608330 /mnt/media/tvshows/SERIEN/WHAT / IF ( (2019) 2024-02-29 10:54:56.819 Debug SqliteItemRepository: GetitemById Series 352595 /mnt/media/tvshows/مسلسلات تركيه 2024-02-29 10:55:03.481 Debug SqliteItemRepository: GetitemById Series 352596 /mnt/media/tvshows/مسلسلات خليجيه I have No Idea what am I doing wrong.. Is there a Keyword, which I have to use to make the Server know this better?
Abobader 3484 Posted February 29, 2024 Posted February 29, 2024 Hello JohnWilburger, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
darkassassin07 670 Posted February 29, 2024 Posted February 29, 2024 What folders have you added to your libraries? From the tree you posted above, you should add each of the folders: 'golf' 'turkish' 'kids', but you should not have 'AR Series' or 'Series' added. https://emby.media/support/articles/TV-Naming.html Under 'Complex Folder Structure'
Luke 42184 Posted March 1, 2024 Posted March 1, 2024 HI, without more information of what you're seeing in Emby, I'm guessing your issue is the same as this: So please follow that other topic. Thanks.
Luke 42184 Posted April 17, 2024 Posted April 17, 2024 54 minutes ago, JohnWilburger said: Thanks I have solved the issue Hi, what was the solution?
