chrisrobbins1970 82 Posted February 27, 2024 Posted February 27, 2024 (edited) How can I setup DDNS (no-ip.com) for remote external access? I have the host created. I put in the host under external access on the synology. Under External domain on the emby network I also added the host name. Under the dashbaord it shows for extneral Remote (WAN) access http://(hostname):8096. I have also added the HTTPS on the router for port forwarding. I can access the server remotly using the public ip address but not using DDNS. What am I missing ? Edited February 27, 2024 by GrimReaper Link removed
Q-Droid 1011 Posted February 27, 2024 Posted February 27, 2024 Let's assume that by hostname you mean the fully qualified domain name you got from no-ip. Is that domain resolving to your public IP address? nslookup <domain> or ping <domain> DDNS needs a method to update the IP should it change. Can your router or Synology box do this? The IP address can be updated manually until you get the updater configured.
mattl1979 3 Posted February 27, 2024 Posted February 27, 2024 I set up a DNS name using DDNS/No-IP and then set up my Asus router to use it. In Emby, I set the full DNS name, i.e. customdomain.ddns.net, as the External Domain under Network. Finally, I port forward the Emby HTTPS port from my router to my NAS. Make sure you have a trusted SSL certificate as well.
chrisrobbins1970 82 Posted February 27, 2024 Author Posted February 27, 2024 (edited) where do I get the a trusted SSL certificate ? Edited February 27, 2024 by chrisrobbins1970
Q-Droid 1011 Posted February 27, 2024 Posted February 27, 2024 You should remove your URL from the first post, it's going to a valid Emby server login.
chrisrobbins1970 82 Posted February 27, 2024 Author Posted February 27, 2024 (edited) My origianl post I am unable to edit update: GrimReaper thank you for removing the link still unable to EDIT. i was going to remove it all together Edited February 27, 2024 by chrisrobbins1970
Happy2Play 9811 Posted February 27, 2024 Posted February 27, 2024 Yes the text is masked but the url in under the text is not. If you can't figure it out the @GrimReapershould be able to fix it.
GrimReaper 4896 Posted February 27, 2024 Posted February 27, 2024 Already removed URL few minutes ago.
chrisrobbins1970 82 Posted February 27, 2024 Author Posted February 27, 2024 I have the host setup on my TP-LINK router and its successful. Also port forwared the 8920 for the synology. On emby I added the host to the external domain. but still not connecting....
Q-Droid 1011 Posted February 27, 2024 Posted February 27, 2024 Are you trying to connect with HTTPS on port 8920? You need to configure Emby with SSL (TLS) for that.
mattl1979 3 Posted February 27, 2024 Posted February 27, 2024 50 minutes ago, chrisrobbins1970 said: where do I get the a trusted SSL certificate ? No-IP provides one as part of your plan. They call it the "No-IP Vital Encrypt DV". In terms of the CSR, getting the certificate in the right format, etc., I believe there is an FAQ somewhere.
chrisrobbins1970 82 Posted February 27, 2024 Author Posted February 27, 2024 I am using the FREE no-ip. It i don;t see where to get a SSL certificate. Do I need to have a PAID version to get the certificate ?
Luke 42241 Posted February 27, 2024 Posted February 27, 2024 7 minutes ago, chrisrobbins1970 said: I am using the FREE no-ip. It i don;t see where to get a SSL certificate. Do I need to have a PAID version to get the certificate ? Hi, there's lots of ways to setup SSL. Have you taken a look at this?
Q-Droid 1011 Posted February 27, 2024 Posted February 27, 2024 44 minutes ago, chrisrobbins1970 said: I am using the FREE no-ip. It i don;t see where to get a SSL certificate. Do I need to have a PAID version to get the certificate ? Explore the options available on Synology. I believe you have options on the platform like DDNS service that can update no-ip, built-in reverse proxy and the ability to obtain certificates from Let's Encrypt. As far as I know they are free.
