gillmacca01 220 Posted February 26, 2024 Posted February 26, 2024 When I try to download the m3u supplied by my iptv provider via Edge or chrome on my laptop, I get the message 'too many redirects'. I know what this means, but if I try to download the same m3u using Samsung internet on my android phone, the file downloads everytime. Trying on edge on my phone fails aswell. I can't add the m3u link to Emby as the file doesn't get downloaded. I've been trying to set up a script on my QNAP, but get the same result. Anyone know why it would download fine using Samsung internet, but fails by any other means?
gillmacca01 220 Posted February 26, 2024 Author Posted February 26, 2024 Just to add. I have tried the suggestions for edge/chrome referencing clearing cookies/data, but still get the same error
visproduction 335 Posted March 11, 2024 Posted March 11, 2024 M3u files on a server are often just redirects to another file. I seen these get daisy chained to multiple other redirect files. I think this might be a method to protect against unallowed downloading of media and just a way to discourage anyone from getting to the actual media file. Also if the redirect have local server links, then trying to run those links from a remote end user server will probably fail, which may be the whole idea of hiding the links in this way. I believe this sequence also comes with the server allowing only connections to be able to refer to other local references in the link. Again this could be a method to stop leeching media that they don't want to allow out directly. Anyway, here is a page that talks about some ways to try to clear this up. https://helpdeskgeek.com/help-desk/how-to-fix-err_too_many_redirects-in-google-chrome/ Hope that helps.
