lizhaoyang555 0 Posted February 25, 2024 Posted February 25, 2024 Installed the 4.8.0.56 server through Synology Docker, purchased a one-year account with the email: 523800858@qq.com. Currently, after entering the key, it keeps spinning without displaying the expiration date. Other clients cannot restore purchases, leading to inability to use it normally.If you are still unable to use it, how can I request a refund?
Happy2Play 9811 Posted February 25, 2024 Posted February 25, 2024 7 hours ago, lizhaoyang555 said: Installed the 4.8.0.56 server through Synology Docker May I ask why? As that is an old beta build. Can you post the server log when you applied the key? @ebr
Luke 42241 Posted February 25, 2024 Posted February 25, 2024 Hi, please try updating to the latest build. If there's still an issue after that, then please email billingsupport@emby.media Thanks !
zgp 5 Posted April 8, 2024 Posted April 8, 2024 In China,The domain mb3admin.com is sometimes blocked,Unable to resolve or unreachable route,you can use ping tool test the domain.
Luke 42241 Posted April 8, 2024 Posted April 8, 2024 1 hour ago, zgp said: In China,The domain mb3admin.com is sometimes blocked,Unable to resolve or unreachable route,you can use ping tool test the domain. Hi, how about using a VPN?
zgp 5 Posted April 12, 2024 Posted April 12, 2024 On 2024/4/8 at PM1点12分, Luke said: 你好,请问使用VPN怎么样? Using the VPN is feasible. This problem doesn't always occur, and sometimes it's normal 1
Luke 42241 Posted April 15, 2024 Posted April 15, 2024 10 hours ago, DarcyGG said: hello你好,我也有同样的问题,请问你解决了吗 Hi there, can you please describe your issue in more detail? Thanks.
ebr 16335 Posted April 15, 2024 Posted April 15, 2024 Also please see: My Emby Key Says it is Invalid or Missing
