gihayes 47 Posted February 25, 2024 Posted February 25, 2024 I recently moved my Emby server to a new computer and then updated to the latest version of Emby, Version 4.8.1.0. I have all four of the Theme Plugins and Emby Premier. Since doing the move and update, the Plugin is no longer keeping it's settings (Normalise Audio for future downloads, Target Maximum Volume, and Be a part of the Theme Contribution Network) and does not appear to be downloading any themes (none are showing up in the 'list of themes that the plugin has downloaded' section). Help.
Luke 42150 Posted February 25, 2024 Posted February 25, 2024 Hi there, the plugin requires an update for Emby Server 4.8, which @radeonis working on. If he doesn't respond to this you could try sending him a PM.
Luke 42150 Posted February 26, 2024 Posted February 26, 2024 He did follow up a few days ago to let us know that he's working on it, so hopefully not too much longer.
gihayes 47 Posted March 1, 2024 Author Posted March 1, 2024 (edited) Thanks for TV Videos fix. Still have the issue with TV Songs, Movie Songs and Movie Videos even though they've been updated and I restarted Emby. A fix coming for those soon too? Also, used to be able to set Target Maximum Volume to -30. Now it seems to allow me to go only to -15. I like it low so I can play Movie at a normal volume, (loud, lol), and be not overwhelmed by themes when browsing Movies or TV. Edited March 1, 2024 by gihayes 1
radeon 757 Posted March 1, 2024 Posted March 1, 2024 They're working fine for me? Whats the issue you're having?
gihayes 47 Posted March 1, 2024 Author Posted March 1, 2024 It was the interface issue. On the three I mentioned. I just rebooted the computer and all is well now. Thanks. Still can't set volume to -30 tho 1
AlexSol 1 Posted September 23, 2024 Posted September 23, 2024 (edited) On 3/1/2024 at 6:54 AM, radeon said: They're working fine for me? Whats the issue you're having? Hi there! Same here. All 4 plugins have the lowest option is "-15". It doesn't look like a UI bug - both Safari and Chrome have the same behaviour. Unfortunately it is way too much loud on my 5.1 system. Could you please check it for sure? I'm on Emby version is beta 4.9.0.30. Logs have nothing about it so didn't attach. P.S. Settings saving works fine for me, the only issue is with Volume level options. Thank you a lot! Edited September 23, 2024 by AlexSol Add more details
