Guest Posted February 24, 2024 Posted February 24, 2024 Hello, I am having a major problem trying to reset my admin password on my Synology NAS. When I go to forgotten password link and click on to it, I get a message asking me to enter my username (screenshot 202901) I get a message telling to go to /var/packages/EmbyServer/var/passwordreset.txt when I click on the Got It tab, I only see (screenshot 203107) and nothing else. How do I find where file /var/packages/EmbyServer/var/passwordreset.txt is to get direction to resetting my admin password. @Carlo
Luke 42241 Posted February 24, 2024 Posted February 24, 2024 @mikem4218 Hi, same question here: Please let us know if this helps. Thanks !
Guest Posted February 25, 2024 Posted February 25, 2024 Hello Luke, I am going get a computer technician to come over to help me out I had a look at the putty program, for me it is like reading Greek. I wish EMBY had a paid technical support like in the old days. At this point in the game I will pay $100.00 to get the problem straightened out. Thanks for your help... @Carlo
Luke 42241 Posted February 27, 2024 Posted February 27, 2024 @mikem4218were you able to try the SSH instructions? It's not as hard as you might think.
Carlo 4561 Posted February 29, 2024 Posted February 29, 2024 Hi @mikem4218 Did you get this resolved yet? If not, I can assist you personally, but I' I've got something I'd like to try first that should expose the file in the web interface so you can access it. Carlo
Guest Posted February 29, 2024 Posted February 29, 2024 Hello yes, I am up and running. Will be able to install EMBY onto my new Formuler Android TV box?
Luke 42241 Posted February 29, 2024 Posted February 29, 2024 55 minutes ago, mikem4218 said: Hello yes, I am up and running. Will be able to install EMBY onto my new Formuler Android TV box? Hi, yes we have Emby apps in the play store for Android/Android TV.
