PalfiZsolt 1 Posted February 23, 2024 Posted February 23, 2024 Hi, I purchased the Emby Premiere right now to have hardware acceleration encoding on my Raspberry Pi 4 emby server. It seems the activation was successful, because based on the log it already tries to use the GPU, but the ffmpeg always failes: 00:35:55.101 [h264_v4l2m2m @ 0x3f487460] VIDIOC_STREAMON failed on output context 00:35:55.101 Video encoding failed 00:35:55.116 [libmp3lame @ 0x3f51b710] 3 frames left in the queue on closing 00:35:55.118 Conversion failed! Then it falls back immediatelly to software encoding. I attached the full log for more details. Any recommendation how to fix the issue? Thanks, Zsolt ffmpeg-transcode-aeed8e92-07e3-47b2-bc7d-aa35bf9c2cb2_1.txt
Solution PalfiZsolt 1 Posted February 24, 2024 Author Solution Posted February 24, 2024 Hi, Finally I found the root cause: the gpu mem size was too low, and likely it was not enough for higher quality videos. If you face similar problem, just increase the value of the gpu_mem config to higher value in the /boot/config.txt. For me the original 32 MB was not enough, but the 64 MB worked. Regards, Zsolt 1
