justinrh 267 Posted February 21, 2024 Posted February 21, 2024 I don't know what day I'm looking at ...
Luke 42241 Posted February 21, 2024 Posted February 21, 2024 Right it makes the column smaller. There is just no room for it.
justinrh 267 Posted February 21, 2024 Author Posted February 21, 2024 Well, you can make the column large just as when Channel Display != both. What's the reason for scrunching it?
Luke 42241 Posted February 22, 2024 Posted February 22, 2024 When the column is wide, some users complain about that. When you're not showing both, the extra width becomes a necessity in order to fit everything on one line and avoid the two line display. So in that situation, nobody really questions it. But you can't fit an image, title and number all on one line without running into text truncation, so then we do the two line display. Maybe we can make it a little wider.
Luke 42241 Posted February 22, 2024 Posted February 22, 2024 At that width you have users complaining about wasted space.
justinrh 267 Posted February 22, 2024 Author Posted February 22, 2024 Yeah, it was an exaggeration. I'm just saying it can be wider, if you choose, so the room can be made, like it is otherwise, so nothing lost. Maybe there is another place to put the day, just thinking for another solution.
