Brendon 124 Posted February 21, 2024 Posted February 21, 2024 As you can see in the screenshot, multi-part episodes are suddenly being treated as different versions, they are 2 different episodes not different versions of the same episode, has the way we name multi-part episodes changed?? As
Happy2Play 9798 Posted February 21, 2024 Posted February 21, 2024 @BrendonWhat is there actual naming scheme?
Brendon 124 Posted February 21, 2024 Author Posted February 21, 2024 @Happy2Playexactly as it always has been for over a decade now mate, however i have just noticed it's only that episode?? The episodes 'My Soul on Fire' are displaying correctly as shown in the attached screenshot
Solution Brendon 124 Posted February 21, 2024 Author Solution Posted February 21, 2024 It appears it was a metadata glitch @Happy2Playboth episodes were showing as episode 18 in the WEB UI, if i changed one to 19 it changed both to 19, i have no idea as to why but that's what happened. I had to manually go and edit the nfo for episode 19 and change it there from 18 to 19 then i went back to emby and refreshed the metadata at season level and episode 19 appeared as it should.
Happy2Play 9798 Posted February 21, 2024 Posted February 21, 2024 But there is no 8x19 but maybe ended up with same provider id?
GrimReaper 4843 Posted February 21, 2024 Posted February 21, 2024 13 minutes ago, Happy2Play said: But there is no 8x19 but maybe ended up with same provider id? There is in DVD order, maybe OP did not change Display order? Scrubs - Unknown - Season 8 - TheTVDB.com 1
DrFumi 0 Posted January 5, 2025 Posted January 5, 2025 I have a few episodes that were doing this, but I didn't have a corresponding nfo file. I numbered the episodes, removed the "part 1" and "part 2" from the titles, and rescanned the library files, and that worked.
