HunterStreet 1 Posted February 19, 2024 Posted February 19, 2024 I have tried installing Emby on my Windows machine. I can go through the installation process and it will run Emby, but Emby doesn't show up in my apps. Anytime I restart the computer, the app is missing and the only fix I have found is to reinstall Emby. I'm assuming there's some issue with getting Emby to fully install on this PC?
Abobader 3484 Posted February 19, 2024 Posted February 19, 2024 Hello HunterStreet, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42184 Posted February 20, 2024 Posted February 20, 2024 Hi there, can you tell us what exactly you installed from where? From the windows store, from our website? Emby Server or Emby Client? Thanks.
HunterStreet 1 Posted February 20, 2024 Author Posted February 20, 2024 It was just the normal Windows install from Emby’s website. Emby server.
kjhedges 67 Posted February 20, 2024 Posted February 20, 2024 Did you download from here https://emby.media/windows-server.html
darkassassin07 670 Posted February 20, 2024 Posted February 20, 2024 Once installed, if you can't find the normal shortcut, you should be able to find the installed app, including its .exe in: C:/users/<your username>/AppData/roaming/emby-server/system Note: the AppData folder is usually hidden. You can view it by either enabling 'show hidden folders' in Windows explorer (the file browser), or by pressing start, typing 'run', press enter, then entering '%appdata%' into that run dialog.
Solution HunterStreet 1 Posted February 21, 2024 Author Solution Posted February 21, 2024 I figured it out. I had a feeling it was an admin issue and it was. It was making me install as an admin, but it would only install Emby on the admin account and not the user account. Just had to move the files. Thanks everyone for the help. 1
