Vahn84 1 Posted February 18, 2024 Posted February 18, 2024 (edited) Hi all guys, i've just recreated my emby container and wasn't surprised to see my duplicati backup didn't help restoring ALL the settings/users/plugins. This is something that has already happened to me. I experienced a server reset even just redeploying my container with portainer (i wanted to update the emby version). No matter how hard i try when i restore a backup i can't login anymore inside my server...and even if i reset the password and get back in the emby dashboard, every setting, plugin, user i had before is gone and need to be setup again I know that there's a proprietary backup with emby premiere (i am a premiere user) but i wanted to keep all my backups managed by the same entity, in this case the duplicati server that's in charge to backup all of my docker containers. Also i'd like to know why all my other docker containers do not reset if i redeploy them while emby does. I've tried searching here and on google but i couldn't find an answer i could understand so...here i am The worst thing is that when this happens the connection with jellyseer is completely broken and i have to setup back again jellyseer from the beginning this is my docker compose in portainer version: "2.3" services: emby: image: emby/embyserver:latest container_name: embyserver network_mode: host # Enable DLNA and Wake-on-Lan environment: - UID=1026 # The UID to run emby as (default: 2) - GID=100 # The GID to run emby as (default 2) - GIDLIST=100 # A comma-separated list of additional GIDs to run emby as (default: 2) volumes: - /volume2/docker/emby:/config - /volume1/data/media/tvshows:/tvshows - /volume1/data/media/movies:/movies # Media directory ports: - 8096:8096 # HTTP port - 8920:8920 # HTTPS port devices: - /dev/dri:/dev/dri # VAAPI/NVDEC/NVENC render nodes restart: on-failure I'd really appreciate any help Edited February 18, 2024 by Vahn84 added a piece of information
Neminem 1610 Posted February 18, 2024 Posted February 18, 2024 Is you jellyfin setup with the same ports as Emby ports: - 8096:8096 # HTTP port - 8920:8920 # HTTPS port Jellyfin took the code from Emby back in the day, and didn't bother to change the default port's.
Vahn84 1 Posted February 18, 2024 Author Posted February 18, 2024 1 hour ago, jaycedk said: Is you jellyfin setup with the same ports as Emby ports: - 8096:8096 # HTTP port - 8920:8920 # HTTPS port Jellyfin took the code from Emby back in the day, and didn't bother to change the default port's. thank you for your reply! I do not have a jellyfin server. I have jellyseerr connected to the emby server
