Ugnaughts 53 Posted February 18, 2024 Posted February 18, 2024 i use to have the option like it says in this article https://emby.media/support/articles/Xml-Tv.html but now it just gives only the option to search by zip code. using emby 4.8.1.0
samuelqwe 317 Posted February 18, 2024 Posted February 18, 2024 (edited) Select any country, and you should have the option to use XMLTV as a guide source. Edited February 18, 2024 by samuelqwe
Luke 42241 Posted February 18, 2024 Posted February 18, 2024 6 minutes ago, joekingcool said: i use to have the option like it says in this article https://emby.media/support/articles/Xml-Tv.html but now it just gives only the option to search by zip code. using emby 4.8.1.0 Hi, can you please be more specific? What option exactly do you think is missing?
Ugnaughts 53 Posted February 18, 2024 Author Posted February 18, 2024 8 minutes ago, samuelqwe said: Select any country, and you should have the option to use XMLTV as a guide source. yes this is the option im missing. after i select country. it only gives me emby data. New Bitmap Image.bmp
Solution Luke 42241 Posted February 18, 2024 Solution Posted February 18, 2024 You probably uninstalled the xmltv plugin. 1
Ugnaughts 53 Posted February 18, 2024 Author Posted February 18, 2024 4 minutes ago, Luke said: You probably uninstalled the xmltv plugin. lol im so sorry, i forgot all about that. 1
