lick2023 1 Posted February 19, 2024 Author Posted February 19, 2024 Headache is difficult to solve, and it needs to be reset every time. Repairing it is almost impossible, it takes too much time!
Luke 42288 Posted February 19, 2024 Posted February 19, 2024 1 hour ago, lick2023 said: The method you provided has been tried several times but has not been successful. The library file is too large, over 1GB. I tried it before, but it hasn't been fixed for half a month! Why is it normal before restarting, but this problem occurs after restarting! What exactly did you do?
lick2023 1 Posted February 19, 2024 Author Posted February 19, 2024 1 hour ago, Luke said: 你到底做了什么? I didn't do anything, everything was normal before restarting, but after restarting, it just couldn't start!
lick2023 1 Posted February 20, 2024 Author Posted February 20, 2024 On 2024/2/19 at AM10点29分, Luke said: 你到底做了什么? I recalled the data and went back to the old version first. Another problem was that I bound the domain name, but played it on the client side, which was too laggy. When I switched servers, I always skipped to the IP, which made it impossible to use the transit traffic! How to solve this!
Luke 42288 Posted February 20, 2024 Posted February 20, 2024 13 hours ago, lick2023 said: When I switched servers, I always skipped to the IP, which made it impossible to use the transit traffic! How to solve this! Hi, what do you mean by this? Can you please describe this in more detail? Thanks.
lick2023 1 Posted February 20, 2024 Author Posted February 20, 2024 1 hour ago, Luke said: 你好,你这是什么意思?您能更详细地描述一下吗?谢谢。 We use domain names to bind IP addresses here. When adding servers, we always add domain names. However, during the playback process, we found that it was not smooth. When we clicked on the top right corner to switch servers, we found that the server displayed not the displayed domain name, but automatically jumped to the server IP address. We did not use the intermediate traffic of the domain name server, which caused the playback to be not smooth! How to solve this!
Luke 42288 Posted February 21, 2024 Posted February 21, 2024 23 hours ago, lick2023 said: We use domain names to bind IP addresses here. When adding servers, we always add domain names. However, during the playback process, we found that it was not smooth. When we clicked on the top right corner to switch servers, we found that the server displayed not the displayed domain name, but automatically jumped to the server IP address. We did not use the intermediate traffic of the domain name server, which caused the playback to be not smooth! How to solve this! HI, does your server dashboard display the remote address that you want to use?
lick2023 1 Posted February 22, 2024 Author Posted February 22, 2024 4 hours ago, Luke said: 您好,您的服务器仪表板是否显示您要使用的远程地址? I used nginx to reverse the IP address and did not bind the domain name to the EMBY console, so the server IP is displayed on the dashboard
Luke 42288 Posted February 23, 2024 Posted February 23, 2024 On 2/21/2024 at 9:11 PM, lick2023 said: I used nginx to reverse the IP address and did not bind the domain name to the EMBY console, so the server IP is displayed on the dashboard why not bind the domain name to the emby console?
lick2023 1 Posted February 24, 2024 Author Posted February 24, 2024 23 hours ago, Luke said: 为什么不将域名绑定到emby控制台呢? Because I have multiple intermediate servers, multiple domain names are reversed, and only one domain name is bound. It doesn't affect me, right!
lick2023 1 Posted February 24, 2024 Author Posted February 24, 2024 On 2024/2/23 at PM3点50分, Luke said: 为什么不将域名绑定到emby控制台呢? Is the domain name bound in the background, or is the real server IP address displayed when switching servers!
Luke 42288 Posted February 24, 2024 Posted February 24, 2024 15 hours ago, lick2023 said: Because I have multiple intermediate servers, multiple domain names are reversed, and only one domain name is bound. It doesn't affect me, right! Hmm, it might actually, because the Emby app initially connects using the address that you entered, but later gets an updated value from the server, in order to stay up to date with address changes.
lick2023 1 Posted February 25, 2024 Author Posted February 25, 2024 42 minutes ago, Luke said: 嗯,实际上可能是这样,因为 Emby 应用程序最初使用您输入的地址进行连接,但后来从服务器获取更新的值,以便及时了解地址更改。 This is very troublesome. It will automatically change to the original server IP address, causing it to be added again every time it is viewed, otherwise it will not be able to use intermediate traffic. How can we solve this problem
Luke 42288 Posted February 25, 2024 Posted February 25, 2024 Do you want all remote connections to use the same domain name?
lick2023 1 Posted February 29, 2024 Author Posted February 29, 2024 On 2024/2/25 at AM8点45分, Luke said: 您希望所有远程连接都使用相同的域名吗? Just don't let it skip the IP address. When the client connects, just keep using that domain name for the connection
lick2023 1 Posted February 29, 2024 Author Posted February 29, 2024 (edited) 还有我用一个正常的版本,在另一台服务器上从4.7.14更新4.8.1,更新不成功,原4.7.14版本正常,没有数据错误,更新完成后,首页一直显示:Emby Server 正在加载中。请显示稍后。然后资源管理器中,emby进程一直占用比较高的CPU和内存,这是什么原因吗? Edited February 29, 2024 by lick2023
Lessaj 486 Posted February 29, 2024 Posted February 29, 2024 2024-03-01 05:25:01.504 Info SqliteItemRepository: Dropping 34466 virtual items You have to wait for it to to finish.
lick2023 1 Posted February 29, 2024 Author Posted February 29, 2024 2 minutes ago, Lessaj said: 你必须等待它完成。 How to optimize this database on the existing version, and then update the new version without waiting? This deletion feels like it will take a long time!
Lessaj 486 Posted February 29, 2024 Posted February 29, 2024 It's a one time activity when you upgrade from 4.7 to 4.8. Just wait for it to finish. 1
lick2023 1 Posted February 29, 2024 Author Posted February 29, 2024 2 minutes ago, Lessaj said: 从 4.7 升级到 4.8 时,这是一次性活动。只需等待它完成即可。 Thank you, how long will it take to wait? Upgrading is quite troublesome, and not upgrading is not enough!
Lessaj 486 Posted February 29, 2024 Posted February 29, 2024 (edited) Unfortunately there isn't much of a way to know, depends on a lot of factors, it could take anywhere from a few minutes to a few hours. It doesn't seem like that many items though, it shouldn't take that long overall. I think it's a single threaded operation. Edited February 29, 2024 by Lessaj
lick2023 1 Posted February 29, 2024 Author Posted February 29, 2024 1 minute ago, Lessaj said: 不幸的是,没有太多方法可以知道,这取决于很多因素,可能需要几分钟到几个小时。虽然看起来没有那么多项目,但总体来说应该不会花那么长时间。我认为这是一个单线程操作。 It's been over an hour and there's no response yet!
lick2023 1 Posted March 1, 2024 Author Posted March 1, 2024 The upgrade was successful. The problem now is that switching servers keeps skipping IP addresses and using server traffic instead of intermediate traffic. How can we solve this problem? We didn't see this phenomenon a while ago, but now we are adding servers. Although it is an added domain name, it will automatically become an IP address later!
Lessaj 486 Posted March 1, 2024 Posted March 1, 2024 I think I understand what you're asking. You're saying that you have a reverse proxy setup, so you have a domain name that you're using, but you're still seeing traffic go directly to the server via IP? Or at some point you get redirected to use the server IP instead of the domain name?
lick2023 1 Posted March 1, 2024 Author Posted March 1, 2024 2 minutes ago, Lessaj said: 我想我明白你在问什么。您是说您有反向代理设置,因此您有一个正在使用的域名,但您仍然看到流量通过 IP 直接流向服务器?或者在某些时候您被重定向到使用服务器 IP 而不是域名? That's right, it's about adding a server, using a domain name to add the server, and using intermediate traffic. However, with just one use, it automatically jumps to the original server IP, resulting in no use of intermediate server traffic!
