Catalyph 10 Posted February 14, 2024 Posted February 14, 2024 when decoding 4k HEVC video files from my samsung galaxy s24 ultra, emby struggles and goes about 11fps but when decoding regular movies not from my phone it goes extremely fast, like 120fps. Is there something in my Cell videos that is causing this? Samsung Cell Phone video: Emby Web 4.8.0.80 Chrome Windows 192.168.0.69 http/1.1 Stream MP4 (144 mbps) HLS (60 mbps 13 fps) Reducing bitrate due to quality setting Video 4K HDR 10 HEVC Transcode (H264 60 mbps) Tone Mapping (Hable) Audio English AAC stereo (Default) Direct Play (256 kbps) 4k HEVC Movie Emby Web 4.8.0.80 Chrome Windows 192.168.0.69 http/1.1 Stream MKV (28 mbps) HLS (42 mbps 373 fps) Converting subtitles directly into video Video Avengers.Endgame.2019.2160p.BluRay.x265.10bit.SDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ Transcode (H264 42 mbps) Audio English Avengers.Endgame.2019.2160p.BluRay.x265.10bit.SDR.DTS-HD.MA.TrueHD.7.1.Atmos-SWTYBLZ Transcode (MP3 192 kbps)
Luke 42184 Posted February 14, 2024 Posted February 14, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Catalyph 10 Posted February 14, 2024 Author Posted February 14, 2024 See attached. embyserver.txt ffmpeg-transcode-ac8b2821-ff66-4634-a2f9-0de26f72c9e6_1.txt ffmpeg-transcode-60084af7-73e4-4db6-8be7-2f38ddd12de7_1.txt
Happy2Play 9799 Posted February 14, 2024 Posted February 14, 2024 (edited) Devs may have to break it down but one decoding was done in software and the other in hardware. &TranscodeReasons=ContainerBitrateExceedsLimit >>>>>> Selected Codecs Decoder Automatic software decoder Encoder NVENC NVIDIA GeForce GTX 1660 SUPER - H.264 (AVC) Adapter #0: 'NVIDIA GeForce GTX 1660 SUPER' ComputeCapability: 7.5 Max Bitrate: 781 Mbit/s - Frame Sizes: max 4096x4096 - Width Alignment: 2 - Height Alignment: 2 Color Formats: NV12, P010, P016 - Bit Depths: 8, 10, 12, 14, 16 Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2) >>>>>> FindVideoDecoder - MediaType: hevc, UseHardwareCodecs: True, HWA-Mode: Advanced Info Checking: 'CUVID NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC)' NoMatch Bitrate (138 Mbit/s) exceeds maximum supported rate (117 Mbit/s) Info Decoder does not match Info Checking: 'NVDEC NVIDIA GeForce GTX 1660 SUPER - H.265 (HEVC)' NoMatch Bitrate (138 Mbit/s) exceeds maximum supported rate (117 Mbit/s) Info Decoder does not match Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' It appears to be a bitrate issue as it exceeds the 117Mbps limit set on hardware. @Catalyph Edited February 14, 2024 by Happy2Play
Catalyph 10 Posted February 15, 2024 Author Posted February 15, 2024 So if it exceeds the max bitrate is switches over to very slow? Is there a setting I can change the max supported rate or is that a none adjustable setting ?
rbjtech 5335 Posted February 16, 2024 Posted February 16, 2024 On 15/02/2024 at 13:23, Catalyph said: So if it exceeds the max bitrate is switches over to very slow? Is there a setting I can change the max supported rate or is that a none adjustable setting ? It's a hardware limitation - but is there any reason you are trying to use a 4K @ 138Mbit/sec - that is very close the maximum UHD specification of 144Mbit/sec! I see the source is from a samsung s24 - that is just an insane bitrate. I get you want 4K 60fps - but 30-40 Mbit/sec is more than ample for very good quality - maybe you have settings on the phone to reduce it ?
Catalyph 10 Posted March 6, 2024 Author Posted March 6, 2024 Sorry.. o reason.. it is just the option on my phone to record with high bit rate.. I didn't know it was THAT high... I have unselected the option amd video is decoded and performs just fine.. not sure why they have this option on a cell phone.. or if it is worth that much extra space. 1
