HumanMusic 2 Posted February 15, 2024 Author Posted February 15, 2024 3 hours ago, jaycedk said: No not really. Stuck like not responding ? Can you send logs from this is happening. Then the devs can have a look at that. Yes, Emby just rescanning immediately once I do remove media folder from one library. No response of JS click event and other type action. The CPU usage of Emby uprising to ~15%, Then all the none responding action will be response at once after few minutes. Feels like Emby server couldn't respond during rescanning progress. It's possible to make Emby not rescanning automatically after media folder added or removed? I couldn't do anything during Emby rescanning. embyserver.txt
Neminem 1623 Posted February 15, 2024 Posted February 15, 2024 This look a lot like these, need a dev to commend. And this
HumanMusic 2 Posted February 15, 2024 Author Posted February 15, 2024 6 minutes ago, jaycedk said: This look a lot like these, need a dev to commend. And this Thanks. Looks like the issue mentioned by these two topics are not fixed yet. Should I start a new topic for reporting my logs?
Neminem 1623 Posted February 15, 2024 Posted February 15, 2024 That is probably be best, that way you keep issues seppret.
HumanMusic 2 Posted February 15, 2024 Author Posted February 15, 2024 1 minute ago, jaycedk said: That is probably be best, that way you keep issues seppret. I will try to reply with logs under these topics first. Thanks for all of this. 1
