Jonathan1683 29 Posted February 13, 2024 Posted February 13, 2024 Hello, For some reason when i use firefox to login nothing happens when i click login, works fine with chrome, but I don't like to use chrome if i dont have to. Just a heads up. thank you
Abobader 3485 Posted February 13, 2024 Posted February 13, 2024 50 minutes ago, Jonathan1683 said: Hello, For some reason when i use firefox to login nothing happens when i click login, works fine with chrome, but I don't like to use chrome if i dont have to. Just a heads up. thank you I am now login with firefox ver: 122.0.1 (64-bit) without any problem. 1
Jonathan1683 29 Posted February 13, 2024 Author Posted February 13, 2024 I see what the issue was i didn't include my @email address and the forum doesn't say incorrect login or tell you why it isn't working it just blinks. 1
Solution Abobader 3485 Posted February 13, 2024 Solution Posted February 13, 2024 @Jonathan1683 Thanks for the feedback, I saw the issue, I will see what case it and fix the issue this week. 2
