tiff1002 7 Posted February 13, 2024 Posted February 13, 2024 One of the things I do regularly, being in a long distance relationship, is watch stuff together remotely over discord screen share. Sometimes youtube sometimes emby and this has always worked really well. It seems in some update to discord there now seems to be some kind of audio driver issue sometimes. Certain high def videos have no sound over screen share and other work fine (there are no errors just no sound). Now I tried to screenshare while watching the same video file opened in VLC and the problem still happens. So this is not the fault of emby it would seem so why am I asking here? Well I wonder if there is a way emby can fix it. I assume the video is being transcoded locally and not server side (I may have mixed up the technical terms there a bit). Is there a way to force the server to do all the work so that the audio is not reliant on an audio driver in discord that is not able to work with some of my higher definition videos.
Solution darkassassin07 670 Posted February 13, 2024 Solution Posted February 13, 2024 (edited) You could try using the convert feature to create a different copy of the file with a different audio codec. Right click on the item > convert. Original folder, next to original files Custom MKV H264 AAC Original quality If the audio's already in AAC swap that setting for MP3. Edited February 13, 2024 by darkassassin07 1
tiff1002 7 Posted February 13, 2024 Author Posted February 13, 2024 I bet this would work but my conversions are failing so I need to work that out first
darkassassin07 670 Posted February 13, 2024 Posted February 13, 2024 Alternatively you could try Handbrake Video Converter.
Lessaj 479 Posted February 13, 2024 Posted February 13, 2024 Sounds like a Discord issue to me, or something localized with your setup - could be multiple output devices for example. If you're doing the screen sharing from the desktop client, try it from a web browser instead to compare, or vice versa if using the web browser already.
tiff1002 7 Posted February 14, 2024 Author Posted February 14, 2024 It was the audio codec. Converting the videos on Emby fixed the problem. 1
