Phish1980 2 Posted February 12, 2024 Posted February 12, 2024 So I'm trying to have emby as a backup to my plex server and everything goes great with all my video libraries....until I get to making my music library. It doesn't import all artists and albums. I have deleted and tried numerous things but it constantly misses 100's of albums and about 20 artists. I have 390 artists and 3,870 albums total. Emby does 376 artists and 3600ish albums. I don't know what to do or why it's not scanning everything in. Much appreciated for some help thanks.
Happy2Play 9799 Posted February 12, 2024 Posted February 12, 2024 If will be really hard to say as Emby relies on embedded tags not folder structure. Guess your only options would be adding media in batches to ensure everything is imported correctly and not possibly merged into something else.
Luke 42184 Posted February 12, 2024 Posted February 12, 2024 Hi there, yes can you please provide a specific example of what you think isn't being scanned? Thanks.
Phish1980 2 Posted February 12, 2024 Author Posted February 12, 2024 Exactly what example are you wanting to know...hate ti use plex as an example but my latest addition to plex music is Phish 12-31-223 and emby doesn't scan it in. I have for Phish alone 974 albums emby scans in 895 of them that's one artist example. Every other library for video works flawless 15 minutes ago, Luke said: Hi there, yes can you please provide a specific example of what you think isn't being scanned? Thanks.
Luke 42184 Posted February 12, 2024 Posted February 12, 2024 OK then, can you please show us your files and folders for Phish 12-31-223, and then show us what you see in Emby? Thanks.
Phish1980 2 Posted February 12, 2024 Author Posted February 12, 2024 7 minutes ago, Luke said: OK then, can you please show us your files and folders for Phish 12-31-223, and then show us what you see in Emby? Thanks.
Phish1980 2 Posted February 12, 2024 Author Posted February 12, 2024 (edited) 3 minutes ago, Luke said: OK, and what do you see in Emby? Last album for Phish is 12-28-23. I'm missing almost 80 album by phish alone..not to mention other artists. Edited February 12, 2024 by Phish1980
Phish1980 2 Posted February 13, 2024 Author Posted February 13, 2024 1 hour ago, Luke said: What do you see in folder view? 34 albums...supposed to be 49 albums
Luke 42184 Posted February 13, 2024 Posted February 13, 2024 1 hour ago, Phish1980 said: 34 albums...supposed to be 49 albums So folder view is just about folders and is not related to albums. How many folders are underneath the Phish folder in windows explorer?
Phish1980 2 Posted February 13, 2024 Author Posted February 13, 2024 12 hours ago, Luke said: So folder view is just about folders and is not related to albums. How many folders are underneath the Phish folder in windows explorer? The exact same as the other views...I guess I don't understand what folder view will give you
Luke 42184 Posted February 18, 2024 Posted February 18, 2024 On 2/13/2024 at 12:00 PM, Phish1980 said: The exact same as the other views...I guess I don't understand what folder view will give you Folder view is a raw view of files and folders. Albums and artists are metadata driven views based on information embedded within your audio files. That's why I'm asking these questions about what you're seeing in one vs. the other because that will help narrow down the source of the problem.
Luke 42184 Posted February 18, 2024 Posted February 18, 2024 So now that we've cleared that up, can you please show a screenshot of the Phish folder in Emby? To get there, start from the Folders tab of the music library. I bet everything will be there. if it's showing in folder view, but not album view, then this means you have audio files that either have no embedded album tag, or something incorrect.
Bottles51 74 Posted February 18, 2024 Posted February 18, 2024 What is your library path? It looks like you have albums in another sub-foulder
Phish1980 2 Posted February 19, 2024 Author Posted February 19, 2024 On 2/17/2024 at 8:18 PM, Luke said: So now that we've cleared that up, can you please show a screenshot of the Phish folder in Emby? To get there, start from the Folders tab of the music library. I bet everything will be there. if it's showing in folder view, but not album view, then this means you have audio files that either have no embedded album tag, or something incorrect. Still only 34 albums still missing alot of albums...supposed to be 49 in this folder
Phish1980 2 Posted February 19, 2024 Author Posted February 19, 2024 19 hours ago, Bottles51 said: What is your library path? It looks like you have albums in another sub-foulder Ya and alot of them show up but not others
Luke 42184 Posted February 19, 2024 Posted February 19, 2024 Hi, we are trying to help you. Can you please answer all of the questions that were asked? Thanks.
Phish1980 2 Posted February 19, 2024 Author Posted February 19, 2024 3 minutes ago, Luke said: Hi, we are trying to help you. Can you please answer all of the questions that were asked? Thanks. Sorry I meant to add a picture
Luke 42184 Posted February 20, 2024 Posted February 20, 2024 And the contents of the corresponding folder in the file system? Please show the complete screenshots so that all of the contents can be seen rather than cropping them into cutouts. Thanks.
Bottles51 74 Posted February 20, 2024 Posted February 20, 2024 (edited) Remove your artist folders from sub-folders or point the library to each of them. You will continue to have problems if you group your artists into collections and have sub-folders. https://emby.media/support/articles/Music-Naming.html Edited February 20, 2024 by Bottles51
Luke 42184 Posted February 20, 2024 Posted February 20, 2024 18 minutes ago, Bottles51 said: Remove your artist folders from sub-folders or point the library to each of them. You will continue to have problems if you group your artists into collections and have sub-folders. https://emby.media/support/articles/Music-Naming.html HI, not necessarily. No specific folder structure is required.
