rostar99 4 Posted February 12, 2024 Posted February 12, 2024 I know the ability to auto-adjust the audio delay and/or account for Bluetooth audio latency has been in the "future" for years now. After searching, I see it's not something likely to be implemented soon. Is there a way to change the app setting directly (app settings file) without UI? Unset for mpv.conf and using audio delay in the file does nothing. It sucks that I have to change the audio delay and bitstream setting (and change back) in Emby every time I use my Bluetooth headphones.
Luke 42235 Posted February 12, 2024 Posted February 12, 2024 Hi, I don't have a ready made example for you, but since our Windows app is mpv-based, you should be able to do it with an mpv.conf file.
rostar99 4 Posted February 12, 2024 Author Posted February 12, 2024 Luke, I tried setting unset(for mpv.conf) in the acceleration setting and put an entry "audio-delay=-450," but it did not change anything. I believe this is because the setting for the audio delay is in the UI under video, so it gets overwritten. This is why I asked if I could change the setting for the app directly instead (emby xml or other settings file ???).
