Flest 9 Posted February 11, 2024 Posted February 11, 2024 Of all the fields for collections, only a few work, it looks strange And collections do not inherit the settings of the “parent” library. I enable some fields but only 1 is shown for the collection I go into the collection and... nothing))) Year - display “from-to” as in TV series Rating – maybe also “from to”? or average
Luke 42245 Posted February 11, 2024 Posted February 11, 2024 First screenshot - the "year to year" text is only used for TV series. Second screenshot - there are currently no settings to control what fields are shown there.
Flest 9 Posted February 11, 2024 Author Posted February 11, 2024 (edited) 15 minutes ago, Luke said: First screenshot - the "year to year" text is only used for TV series. It's true, but why? It makes sense to display this information for collections as well. 15 minutes ago, Luke said: Second screenshot - there are currently no settings to control what fields are shown there. I understand this, so I suggest making these settings. Although there is no need to do them, it is much better to use the current library field settings (inherit settings) Edited February 11, 2024 by Flest 1
Luke 42245 Posted February 11, 2024 Posted February 11, 2024 Quote It's true, but why? It makes sense to display this information for collections as well. Currently this information isn't tracked in your server database.
Flest 9 Posted February 12, 2024 Author Posted February 12, 2024 9 hours ago, Luke said: Currently this information isn't tracked in your server database. but why? the server contains all the necessary data, just display it. This looks better than empty collection fields, doesn't it? This will require “calculations”, but they are the simplest, we calculate the average rating and display it. for "years" - just min-max movies and TV series inside a collection already have all the data for the fields and they are displayed if the collections are disabled. In this case, the server definitely has the necessary data, right? :) These literally a few lines of code (((
Luke 42245 Posted February 12, 2024 Posted February 12, 2024 33 minutes ago, Flest said: but why? the server contains all the necessary data, just display it. This looks better than empty collection fields, doesn't it? This will require “calculations”, but they are the simplest, we calculate the average rating and display it. for "years" - just min-max movies and TV series inside a collection already have all the data for the fields and they are displayed if the collections are disabled. In this case, the server definitely has the necessary data, right? :) These literally a few lines of code ((( I guess it just hasn't come up before to be honest. But it's certainly doable.
Flest 9 Posted February 12, 2024 Author Posted February 12, 2024 2 minutes ago, Luke said: I guess it just hasn't come up before to be honest. But it's certainly doable. Thanks ) waiting for updates!! soon I will support emby and buy a lifetime key. problems with payment 1
Flest 9 Posted March 15, 2024 Author Posted March 15, 2024 +1 Problem with collections, field “unwatched” does not work for collections (((( 62 unwatched or 65? ))) collections...
gillmacca01 220 Posted March 15, 2024 Posted March 15, 2024 48 minutes ago, Flest said: +1 Problem with collections, field “unwatched” does not work for collections (((( 62 unwatched or 65? ))) collections... Both screenshots add up to 62
Flest 9 Posted March 15, 2024 Author Posted March 15, 2024 Just now, gillmacca01 said: Both screenshots add up to 62 why not 65? films are also "unwatched" ) Movies display a "watched" icon series "unwatched" if the collection contains TV series and films, this is what you get...
