seashell 42 Posted February 11, 2024 Posted February 11, 2024 Am I missing this somewhere in the settings? I run the server in a small container image but it's storing all the metadata in /var/lib/emby. Yes, I can check individual libraries to store it elsewhere, but livetv, people, temp, etc. is still going to /var/lib on the tiny filesystem as opposed to the (relatively) huge media storage that's available. Yes, I can just symlink the whole /var/lib where I want it if that's what it takes. But surely there has to be a setting for this I'm missing right?
Solution Luke 42238 Posted February 11, 2024 Solution Posted February 11, 2024 HI, what exactly is it that you would like a setting for? There is an option in advanced library settings for the servers' internal metadata folder path.
seashell 42 Posted February 11, 2024 Author Posted February 11, 2024 29 minutes ago, Luke said: HI, what exactly is it that you would like a setting for? There is an option in advanced library settings for the servers' internal metadata folder path. That's the one I wanted. I figured I had to be missing it somewhere. Totally missed the whole advanced tab at the top of the libraries page. Thank you.
seashell 42 Posted February 11, 2024 Author Posted February 11, 2024 @Lukecan I copy the contents of the existing metadata folder under /var/lib to my new location in the setting and delete the old one?
seashell 42 Posted February 11, 2024 Author Posted February 11, 2024 Ok, this is frustrating. I put a new location in that setting, but now all the people images are missing. I didn't delete the old location, but it seems it's not looking there anymore. So I copied the metadata to the new folder and that didn't help either. Looking at the webpage its got new presumably UUID tags for people images. Which apparently aren't translating to the new or the old location. Doing a refresh metadata on a movie, series, library, etc. doesn't refresh the people. How do I move metadata folder to a new location and get all the pointers to update correctly? It makes no sense for it not point to new or old.
Luke 42238 Posted February 11, 2024 Posted February 11, 2024 7 minutes ago, seashell said: Ok, this is frustrating. I put a new location in that setting, but now all the people images are missing. I didn't delete the old location, but it seems it's not looking there anymore. So I copied the metadata to the new folder and that didn't help either. Looking at the webpage its got new presumably UUID tags for people images. Which apparently aren't translating to the new or the old location. Doing a refresh metadata on a movie, series, library, etc. doesn't refresh the people. How do I move metadata folder to a new location and get all the pointers to update correctly? It makes no sense for it not point to new or old. Hi, the instructions are underneath the field in the help text. Did you follow them?
seashell 42 Posted February 11, 2024 Author Posted February 11, 2024 All that does is replace blank images with old board game piece images instead.
Luke 42238 Posted February 11, 2024 Posted February 11, 2024 OK please start by spelling out exactly everything that you did. it's also possible that you might have configured a location that the server is being denied access to: How to Report a Problem Thanks.
Happy2Play 9811 Posted February 11, 2024 Posted February 11, 2024 Issue will always be original location will have default token path. You provide a custom path and now that token is broken unless you manually update every entry in the database with your new custom path. So, in reality you have to set all custom paths before ever creating a library and it can never change without some database hacking. But blanket updating somethings are pretty easy with one line updates.
seashell 42 Posted February 11, 2024 Author Posted February 11, 2024 I have copied all data from old to new location (cp -ra as root, yes permission are preserved. Yes it has write access it can write there as I can manually update a person and it works.) Run scan metadata task Run scan media library task Done refresh metadata at the top level of libraries with replace all images. One library brought back people pictures. Everything else has board game pieces. Sigh.
Happy2Play 9811 Posted February 11, 2024 Posted February 11, 2024 @LukeDoes the metadata folder scan auto update the token to new path?
seashell 42 Posted February 11, 2024 Author Posted February 11, 2024 What's the point of a %MetadataPath% token if it doesn't update to the new path?
Luke 42238 Posted February 11, 2024 Posted February 11, 2024 2 minutes ago, Happy2Play said: @LukeDoes the metadata folder scan auto update the token to new path? Everything is tokenized in the database so there's actually nothing to update.
Happy2Play 9811 Posted February 11, 2024 Posted February 11, 2024 1 minute ago, seashell said: What's the point of a %MetadataPath% token if it doesn't update to the new path? Originally copy entire Emby server folder and relocate as it is self contained. But different platforms have different install location so it may be specific to programdata folder. Custom locations are tokenized at all.
Luke 42238 Posted February 11, 2024 Posted February 11, 2024 What might have happened is metadata/metadata.
Happy2Play 9811 Posted February 11, 2024 Posted February 11, 2024 Just now, Luke said: Everything is tokenized in the database so there's actually nothing to update. But custom paths are outside of default token. Will test again shortly as %MetadataPath% does not equal custom C:\Emby Stuff\metadata as written in database. Unless something has changed.
seashell 42 Posted February 11, 2024 Author Posted February 11, 2024 No there is not metadata/metadata. (I checked that before writing.) And that wouldn't explain why one library came back and not the others. I'm just deleting and re-adding libraries at this point.
Happy2Play 9811 Posted February 11, 2024 Posted February 11, 2024 Retested and applying custom path and moving from default maintain token path images as custom path become the token. Images where broken until moving every from default to custom. My test was on Windows as all other platforms will have to ensure your permissions are correct.
seashell 42 Posted February 11, 2024 Author Posted February 11, 2024 Yeah that was a complete PITA. Had to redo all the libraries, and my TV one wouldn't scan correctly as it got hung up on a specials folder in one directory just saying error about image extraction. So I moved that whole show out and the scan worked. Then I added that show and emby added it without the specials, didn't even try them. No amount of scanning would get it to show the specials folder even existed. I finally had to move the Specials folder out of that directory, make a new one, and move the files back into it. Then it worked fine. Note that the thumbnails were sitting there already so I don't know why it even wanted new ones. And no idea why the folder it had been completely happy with was now a problem. As a lark with "brand new" libraries I tried refreshing metadata again on the combined episode test. It's still applying a single episode number. (Wrong thread I suppose.)
seashell 42 Posted February 11, 2024 Author Posted February 11, 2024 Yep it's definitely struggling with one show. It's actually failing on the main show not the specials. I guess it just never got to them as the timeout on the three actual parts is really really long. Looks like if I had waited and waited and waited it would have gone on. LOG of trying to update metadata on the first part. System.Exception: System.Exception: Error running ffmpeg quick-extract-image for file:"/usb16t/media/tv/Shogun (1980)/Season 1/Shogun - S01E01 - Part 1.mkv" - Command: -f matroska -threads 1 -copyts -i file:"/usb16t/media/tv/Shogun (1980)/Season 1/Shogun - S01E01 - Part 1.mkv" -map 0:5 -update 1 -vf "scale=trunc(min(max(iw\,ih*dar)\,600)/2)*2:trunc(ow/dar/2)*2" -vsync 0 -f image2 "/usb16t/media/embyserver/cache/temp/52e8b87b-8938-42ad-9d06-de78e8252813.jpg" at Emby.Server.MediaEncoding.ImageExtraction.ImageExtractorBase.RunExtraction(String inputPath, Nullable`1 container, MediaStream videoStream, Nullable`1 protocol, Nullable`1 streamIndex, Nullable`1 threedFormat, Nullable`1 startOffset, Nullable`1 interval, String targetDirectory, String targetFilename, Nullable`1 maxWidth, Boolean enableThumbnailFilter, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.ImageExtraction.ImageExtractionManager.ExtractImageInternal(ReadOnlyMemory`1 inputPath, Nullable`1 container, MediaStream videoStream, Nullable`1 streamIndex, Nullable`1 threedFormat, Nullable`1 offset, Boolean useThumbNailFilter, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.ImageExtraction.ImageExtractionManager.ExtractImage(ReadOnlyMemory`1 inputPath, Nullable`1 container, MediaStream videoStream, Nullable`1 streamIndex, MediaProtocol protocol, Boolean isAudio, Nullable`1 threedFormat, Nullable`1 offset, CancellationToken cancellationToken) at Emby.Providers.MediaInfo.VideoImageProvider.GetImage(BaseMetadataResult itemResult, ImageType type, CancellationToken cancellationToken) at Emby.Providers.Manager.ItemImageProvider.RefreshFromProvider(BaseMetadataResult itemResult, IDynamicImageProvider provider, Boolean providerReportsChanges, ImageRefreshOptions refreshOptions, Boolean replaceAllImages, TypeOptions savedOptions, LibraryOptions libraryOptions, List`1 downloadedImages, RefreshResult result, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() END LOG Here's a manual run of the command and it's output. It sits for a long time and then spits out an image that is actually the attachment of the mkv not a screen grab. Oddly there was no issue playing this file though. /opt/emby-server/bin/ffmpeg -f matroska -threads 1 -copyts -i file:"/usb16t/media/tv/Shogun (1980 )/Season 1/Shogun - S01E01 - Part 1.mkv" -map 0:5 -update 1 -vf "scale=trunc(min(max(iw\,ih*dar)\,600)/2)*2:trunc(ow/dar/2)*2" -vsync 0 -f image2 te st.jpg ffmpeg version 5.1-emby_2023_06_25 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 10.3.0 (crosstool-NG 1.25.0) Execution Date: 2024-02-11 16:12:42 -vsync is deprecated. Use -fps_mode Passing a number to -vsync is deprecated, use a string argument as described in the manual. [matroska,webm @ 0x1c48440] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options Input #0, matroska,webm, from 'file:/usb16t/media/tv/Shogun (1980)/Season 1/Shogun - S01E01 - Part 1.mkv': Metadata: title : Shogun Part 1 encoder : libmakemkv v1.17.5 (1.3.10/1.5.2) x86_64-suse-linux creation_time : 2023-12-29T07:39:03.000000Z Duration: 02:50:50.86, start: 0.000000, bitrate: 25182 kb/s Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], Level 41, 23.98 fps, 23.98 tbr, 1k tbn Metadata: BPS-eng : 19903467 DURATION-eng : 02:50:50.114875000 NUMBER_OF_FRAMES-eng: 245757 NUMBER_OF_BYTES-eng: 25501601106 SOURCE_ID-eng : 001011 Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), s32p (24 bit) (default) Metadata: title : Surround 5.1 BPS-eng : 3554236 DURATION-eng : 02:50:50.852244444 NUMBER_OF_FRAMES-eng: 961010 NUMBER_OF_BYTES-eng: 4554243732 SOURCE_ID-eng : 001100 Stream #0:2(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s Metadata: title : Surround 5.1 BPS-eng : 1508988 DURATION-eng : 02:50:50.852244444 NUMBER_OF_FRAMES-eng: 961010 NUMBER_OF_BYTES-eng: 1933552120 SOURCE_ID-eng : 001100 Stream #0:3(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s Metadata: title : Stereo BPS-eng : 191999 DURATION-eng : 02:50:50.862911111 NUMBER_OF_FRAMES-eng: 320338 NUMBER_OF_BYTES-eng: 246019584 SOURCE_ID-eng : 001101 Stream #0:4(eng): Subtitle: hdmv_pgs_subtitle Metadata: BPS-eng : 20779 DURATION-eng : 02:48:34.667062500 NUMBER_OF_FRAMES-eng: 2664 NUMBER_OF_BYTES-eng: 26271648 SOURCE_ID-eng : 001200 Stream #0:5: Video: mjpeg (Baseline), yuvj444p(pc, bt470bg/unknown/unknown), 640x360, 90k tbr, 90k tbn (attached pic) Metadata: filename : cover.jpg mimetype : image/jpeg File 'test.jpg' already exists. Overwrite? [y/N] y Stream mapping: Stream #0:5 -> #0:0 (mjpeg (native) -> mjpeg (native)) Press [q] to stop, [?] for help [swscaler @ 0x1ca3840] [swscaler @ 0x1c78480] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x1d930c0] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x21c0900] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x2475d00] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x24a18c0] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x24bac80] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x1c7bb00] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x21ade80] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x2463dc0] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x248f540] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x24bac80] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x1c7bb00] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x21ade80] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x2463300] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x248f540] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x24bac80] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x1c7bb00] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x1d91080] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x21be700] deprecated pixel format used, make sure you did set range correctly [swscaler @ 0x1ca3840] [swscaler @ 0x24904c0] deprecated pixel format used, make sure you did set range correctly Output #0, image2, to 'test.jpg': Metadata: title : Shogun Part 1 encoder : Lavf59.27.100 Stream #0:0: Video: mjpeg, yuvj444p(pc, bt470bg/unknown/unknown, progressive), 600x336, q=2-31, 200 kb/s, 90k fps, 90k tbn (attached pic) Metadata: filename : cover.jpg mimetype : image/jpeg encoder : Lavc59.37.100 mjpeg Side data: cpb: bitrate max/min/avg: 0/0/200000 buffer size: 0 vbv_delay: N/A elapsed=00:02:04.92 frame= 1 fps=0.0 q=6.3 Lsize=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x video:27kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown EXIT
Luke 42238 Posted February 18, 2024 Posted February 18, 2024 On 2/11/2024 at 4:48 PM, Happy2Play said: Retested and applying custom path and moving from default maintain token path images as custom path become the token. Images where broken until moving every from default to custom. My test was on Windows as all other platforms will have to ensure your permissions are correct. What do you mean by "custom path become the token"?
Happy2Play 9811 Posted February 18, 2024 Posted February 18, 2024 1 minute ago, Luke said: What do you mean by "custom path become the token"? New path is honored as token. %MetadataPath%=whatever path is set to so everything must reside in set new path or it is now broken and has to be recreated.
Luke 42238 Posted February 18, 2024 Posted February 18, 2024 8 minutes ago, Happy2Play said: New path is honored as token. %MetadataPath%=whatever path is set to so everything must reside in set new path or it is now broken and has to be recreated. OK. Does the help text underneath the option adequately explain this, do you think?
Happy2Play 9811 Posted February 18, 2024 Posted February 18, 2024 1 minute ago, Luke said: OK. Does the help text underneath the option adequately explain this, do you think? No it looks good. Just didn't remember working previously and required manual db path updates. 1
Luke 42238 Posted February 18, 2024 Posted February 18, 2024 On 2/11/2024 at 5:32 PM, seashell said: Yeah that was a complete PITA. Had to redo all the libraries I don't think you actually had to do this.
