AWG97 3 Posted February 11, 2024 Posted February 11, 2024 So, I'm using couple of WiFi networks regularly and often I have to switch between the 2. As mentioned in the topic, for example: when on the 'Home' page, after switching the WiFi network, it stops loading content and refuse to reload unless I close the app and open it again. Changing the network while playing media doesn't seem to affect the playback or anything. The problem only comes up when loading content on the interface.
AWG97 3 Posted February 26, 2024 Author Posted February 26, 2024 (edited) On 2/18/2024 at 5:27 AM, Luke said: @AWG97is this the Emby android app? correct. v3.3.66 Edited February 26, 2024 by AWG97
Luke 42243 Posted February 27, 2024 Posted February 27, 2024 Quote So, I'm using couple of WiFi networks regularly and often I have to switch between the 2. As mentioned in the topic, for example: when on the 'Home' page, after switching the WiFi network, it stops loading content and refuse to reload unless I close the app and open it again. Changing the network while playing media doesn't seem to affect the playback or anything. The problem only comes up when loading content on the interface. HI, it should be able to recover if you give it enough time. Did you give it a good 20 seconds or more?
AWG97 3 Posted February 27, 2024 Author Posted February 27, 2024 3 minutes ago, Luke said: HI, it should be able to recover if you give it enough time. Did you give it a good 20 seconds or more? Ok, I've tested it several times now. It seems to recover after ~30 seconds. Guess I should be more patient with it :))
Luke 42243 Posted February 27, 2024 Posted February 27, 2024 We'll look at making that recovery faster. Thanks. 2
