REDNINJA 0 Posted February 11, 2024 Posted February 11, 2024 Guten Tag in die Runde, ich habe meine Vu+ Duo4K per M3U in Emby eingebunden und habe verschieden Ordner für Film und Serienaufnahmen angelegt. Mein Problem ist das Emby egal welche Aufnahme immer in den Serien Ordner aufnimmt. gibt es eine versteckte Config Datei wo ich ggf. noch Einstellungen tätigen muss?? hier einmal meine Aufnahme Einstellungen: Hier die verschiedenen Ordner: Und noch meine Bibliotheken für die Aufnahmen: Hat Wer ggf. eine Solution für mich? Danke schon einmal im voraus.
Luke 42239 Posted February 11, 2024 Posted February 11, 2024 Hi there, can you please provide a specific example? How to Report a Problem Thanks.
REDNINJA 0 Posted February 11, 2024 Author Posted February 11, 2024 Das Problem ist ganz einfach. Jegliche Aufnahme wird im Serien Ordner gespeichert. Egal ob Film oder Serie. Gruß Red
Luke 42239 Posted February 17, 2024 Posted February 17, 2024 @REDNINJAplease provide the emby server log from the time of the recording. How to Report a Problem Thanks.
REDNINJA 0 Posted February 18, 2024 Author Posted February 18, 2024 Good Morning, here the server log from last night. I recorded the Movie "James Bond - 007 jagt Dr. No" but instead recording in the folder "Filme" it was saved in the folder "Serien". I have no Idea why..... embyserver.txt
REDNINJA 0 Posted February 18, 2024 Author Posted February 18, 2024 And here an other example for the Movie "Jorinde und Joringel" again recorded in the folder "Serien" (TVShows) embyserver.txt
REDNINJA 0 Posted February 18, 2024 Author Posted February 18, 2024 It is a link to a Rytec xmltv data for germany.
Luke 42239 Posted February 18, 2024 Posted February 18, 2024 How is this program presented in Emby Live TV? can you please show a screenshot? thanks.
REDNINJA 0 Posted February 19, 2024 Author Posted February 19, 2024 Hello Luke attached two Screenshots from my TV Guide. First is a General one and second detailed from a movie.
pünktchen 1410 Posted February 19, 2024 Posted February 19, 2024 Anhand deiner EPG-Daten denkt Emby "Lethal Weapon" ist eine Serie, ansonsten wäre "Serie aufnehmen" gar nicht verfügbar. Bearbeite mal deine EPG-Quelle in Emby und weise "Spielfilm" der "Filmkategorie" zu:
REDNINJA 0 Posted February 19, 2024 Author Posted February 19, 2024 Habe ich gestern eigentlich gemacht. Muss man danach den Server neu starten? Bisher habe ich keine Änderungen bemerkt...
pünktchen 1410 Posted February 19, 2024 Posted February 19, 2024 5 minutes ago, REDNINJA said: Habe ich gestern eigentlich gemacht. Muss man danach den Server neu starten? Nee, nur die Programdaten aktualisieren. Im schlimmsten Fall mal die EPG-Quelle entfernen und wieder hinzufügen.
REDNINJA 0 Posted February 19, 2024 Author Posted February 19, 2024 Ok dann muss ich das mit dem Entfernen mal antesten. Da es bisher keinen Effect hat. (Siehe Screenshot)
REDNINJA 0 Posted February 19, 2024 Author Posted February 19, 2024 Könnte es denn sein das das EPG von Rytec nicht gut oder okay ist? Gibt es denn Alternativen für Sat Fernsehen inkl. HD+ Paket?
pünktchen 1410 Posted February 19, 2024 Posted February 19, 2024 2 hours ago, REDNINJA said: Könnte es denn sein das das EPG von Rytec nicht gut oder okay ist? Naja, vielleicht nur nicht gut in Zusammenhang mit Emby. Man könnte aber auch sagen, Emby ist in seinen Möglichkeiten zu eingeschränkt. Warum kann man denn die Aufnahmebibliothek nicht für jede Aufnahme separat einstellen?! 2 hours ago, REDNINJA said: Gibt es denn Alternativen für Sat Fernsehen inkl. HD+ Paket Kostenlos oder auch gegen Geld?
Luke 42239 Posted February 20, 2024 Posted February 20, 2024 10 hours ago, pünktchen said: Nee, nur die Programdaten aktualisieren. Im schlimmsten Fall mal die EPG-Quelle entfernen und wieder hinzufügen. You don't need to remove the guide source. Just run the guide refresh after editing it. Please let us know if this helps. Thanks.
REDNINJA 0 Posted February 20, 2024 Author Posted February 20, 2024 Gestern Abend noch mal getestet, leider ohne Erfolg. Habe die Filmkategorie geändert so wie oben auf dem Screenshot. Die Aufnahmen landen weiterhin im Serien Ordner. @pünktchenwenn das Epg auch die Staffel Informationen enthällt kann es meinetwegen auch was kosten. Wie gesagt derzeit bin ich mit meiner jetzigen Lösung nucht zufrieden.
Luke 42239 Posted February 20, 2024 Posted February 20, 2024 Quote Tested again last night, unfortunately without success. I changed the film category like in the screenshot above. The recordings continue to end up in the series folder. Can you please show the specific example of what was recorded last night? Maybe the recording from last night requires additional categories to be added to the settings screen.
REDNINJA 0 Posted March 17, 2024 Author Posted March 17, 2024 Nabend, so bin wieder zu Hause und habe alles noch einmal angepasst. Es bleibt dabei das Filme in Serien Aufgenommen werden.... Bin mit meinem Latein am Ende.
REDNINJA 0 Posted March 22, 2024 Author Posted March 22, 2024 So ich habe das Problem identifiziert... Emby sucht in der XMLTV Datei nach dem Feld <category lang="de">Action</category> Wenn ich nun in den Filmkategorien Action eingebe wird alles was mit Action Kategorisiert wird als Film Angegeben. Dies gilt dann leider auch für Serien.... als Beispiel CSI: NY welche dann nicht mehr als Serie sondern als Film erkannt wird. <title lang="de">CSI: NY</title> <desc lang="de" desc="Danny sitzt in der U-Bahn und freut sich auf seinen Feierabend, als er etwas entdeckt, das seine Pläne zunichte macht: Auf den Gleisen liegt ein menschlicher Körper. Er alarmiert den Fahrer der Bahn, der im letzten Moment bremsen kann.">Danny sitzt in der U-Bahn und freut sich auf seinen Feierabend, als er etwas entdeckt, das seine Pläne zunichte macht: Auf den Gleisen liegt ein menschlicher Körper. Er alarmiert den Fahrer der Bahn, der im letzten Moment bremsen kann.</desc> <credits> <producer>Andrew Lipsitz</producer> </credits> <date>2006</date> <category lang="de">Krimi</category> <category lang="de">Action</category> <category lang="de">Thriller</category> <category lang="de">Fantasy</category> <icon src="http://ngiss.t-online.de/cm1s/media/gracenote/3/0/p3035799_e_h9_ad_2022-05-30T11_56_17.jpg"/> <country lang="de">US</country> <episode-num system="xmltv_ns">1.12.</episode-num> Im deutschen EPG von Rytec wird die Angabe Spielfilm wie folgt hinterlegt: <sub-title lang="de">Spielfilm, Agentenfilm ║ 1995 ║ USA/GB</sub-title> Somit kann Emby diese Filme auch nicht als Film erkennen. Es ist ein Dilemma welches EPG Kategorisiert denn Filme als Film, Movie, Spielfim oder sonstiges??
Luke 42239 Posted March 23, 2024 Posted March 23, 2024 14 hours ago, REDNINJA said: So ich habe das Problem identifiziert... Emby sucht in der XMLTV Datei nach dem Feld <category lang="de">Action</category> Wenn ich nun in den Filmkategorien Action eingebe wird alles was mit Action Kategorisiert wird als Film Angegeben. Dies gilt dann leider auch für Serien.... als Beispiel CSI: NY welche dann nicht mehr als Serie sondern als Film erkannt wird. <title lang="de">CSI: NY</title> <desc lang="de" desc="Danny sitzt in der U-Bahn und freut sich auf seinen Feierabend, als er etwas entdeckt, das seine Pläne zunichte macht: Auf den Gleisen liegt ein menschlicher Körper. Er alarmiert den Fahrer der Bahn, der im letzten Moment bremsen kann.">Danny sitzt in der U-Bahn und freut sich auf seinen Feierabend, als er etwas entdeckt, das seine Pläne zunichte macht: Auf den Gleisen liegt ein menschlicher Körper. Er alarmiert den Fahrer der Bahn, der im letzten Moment bremsen kann.</desc> <credits> <producer>Andrew Lipsitz</producer> </credits> <date>2006</date> <category lang="de">Krimi</category> <category lang="de">Action</category> <category lang="de">Thriller</category> <category lang="de">Fantasy</category> <icon src="http://ngiss.t-online.de/cm1s/media/gracenote/3/0/p3035799_e_h9_ad_2022-05-30T11_56_17.jpg"/> <country lang="de">US</country> <episode-num system="xmltv_ns">1.12.</episode-num> Im deutschen EPG von Rytec wird die Angabe Spielfilm wie folgt hinterlegt: <sub-title lang="de">Spielfilm, Agentenfilm ║ 1995 ║ USA/GB</sub-title> Somit kann Emby diese Filme auch nicht als Film erkennen. Es ist ein Dilemma welches EPG Kategorisiert denn Filme als Film, Movie, Spielfim oder sonstiges?? Hi, this is a series due to the episode number: <episode-num system="xmltv_ns">1.12.</episode-num> Isn't CSI a series anyway?
REDNINJA 0 Posted March 23, 2024 Author Posted March 23, 2024 Right CSI isn´t longer a series for my Emby due to the fact of the category. Is Emby looking for the episode-num system to identify a series?
Luke 42239 Posted March 25, 2024 Posted March 25, 2024 On 3/23/2024 at 5:55 AM, REDNINJA said: Right CSI isn´t longer a series for my Emby due to the fact of the category. Is Emby looking for the episode-num system to identify a series? There are several techniques being used to determine that something is a series vs. a movie, and yes, episode-num is one of them. Does this answer your questions?
REDNINJA 0 Posted March 25, 2024 Author Posted March 25, 2024 Thanks for Information. From my point of view emby is not working properly to identify a series. For me i have found a solution with another EPG guide, that is working good for my needs.
