Luke 42150 Posted December 1, 2024 Posted December 1, 2024 Quote The backup has to be on the same folder as Emby is (in my case: Docker - Emby) or i can use one on the main volume? Also, since i'm using Container Manager, i didn't need to create an Emby user, so i don't know how to do in my case. Hi, you can specify the backup to be stored in any folder you want, no?
Kurt13 11 Posted December 1, 2024 Posted December 1, 2024 5 minutes ago, Luke said: Hi, you can specify the backup to be stored in any folder you want, no? I created a shared folder (/volume1/Emby Backup-Restore plugin) but it doesn't work. Do i have to include this path on the Emby settings on Container Manager with r/w like my media files? Thanks
Luke 42150 Posted December 1, 2024 Posted December 1, 2024 17 hours ago, Kurt13 said: I created a shared folder (/volume1/Emby Backup-Restore plugin) but it doesn't work. Do i have to include this path on the Emby settings on Container Manager with r/w like my media files? Thanks Hi, most likely, yes. You will generally need to do this for any folder that the server touches, whether it's media files or not.
Kurt13 11 Posted December 1, 2024 Posted December 1, 2024 2 hours ago, Luke said: Hi, most likely, yes. You will generally need to do this for any folder that the server touches, whether it's media files or not. I got it! Thanks 1
