OSBuckeyes4Life 12 Posted February 8, 2024 Posted February 8, 2024 (edited) I run Emby in ProxMox and use the Helper script, I also am seeing issues, I have tried different locations, Hope this helps in identifying the issue, I rotated logs so you had less to look at first . Nothing is sticking out to me to point me to what the issue is in the logs. embyserver (4).txt embyserver-63842991016.txt Edited February 8, 2024 by OSBuckeyes4Life Added Server Log
Luke 42244 Posted February 8, 2024 Posted February 8, 2024 @OSBuckeyes4LifeHi, what issues are you seeing?
OSBuckeyes4Life 12 Posted February 8, 2024 Author Posted February 8, 2024 So My backup ran just fine in the past, without hiccup. Now when I run backups, it just fails after 5-7 seconds.
Luke 42244 Posted February 8, 2024 Posted February 8, 2024 Is your backup location some kind of network or nfs mount? The new backup function is using sqlite backup functions to backup the database. sqlite doesn't run well with nfs: https://www.sqlite.org/faq.html#q5
OSBuckeyes4Life 12 Posted February 9, 2024 Author Posted February 9, 2024 Yeah it’s a Synology /mnt, I mean I can try locally on my server but I’m not a super big fan of that. I’ll let you know if I run into any issues.
Luke 42244 Posted February 9, 2024 Posted February 9, 2024 Ok that would be helpful to know the result of that. Thanks.
