DarkStar1977 120 Posted February 11, 2024 Author Posted February 11, 2024 3 hours ago, Luke said: Can you please provide a specific example? Yeah, sure @Luke My TV Shows library is composed by this 3 folders: For the purpose of this example I've added 2 new shows to 1st folder: 1st Folder: And this is what's shown after Emby detects the new shows added: 2 First shows recently added (Time after Time and Incorportated) to folder 1: After running a library scan, not from library but from scheduled tasks, this is what's shown on recently added shows: Latest added shows after Library Scan run from Scheduled Tasks: These shows are the latest added to folder 3, but not to the library Folder 3: So my guess is that the "Library Scan" Scheduled Task, that is executed daily goes secuential folder by folder and when finishes folder 3, understand that those are the latest added shows to the library ignoring if the other folders has more recent added shows, but's only my guess. Hope this helps.
Luke 42237 Posted February 11, 2024 Posted February 11, 2024 OK, did you use the metadata editor to check the date added value for the episodes of those series? That is what drives the order to the latest list.
DarkStar1977 120 Posted February 11, 2024 Author Posted February 11, 2024 2 hours ago, Luke said: OK, did you use the metadata editor to check the date added value for the episodes of those series? That is what drives the order to the latest list. Yes, those episodes are marked with later date added, but this is not true: Data from metadata editor: Real date file was added to the folder and added to the library for first time: (The example is from Episodes from Galactica 1980) For any strange reason every time an scheduled Library Scan Runs, the tv shows added to folder 3 are re-added with the scan date of the scheduled task (I have my schedule daily at 3am in the morning)
Luke 42237 Posted February 12, 2024 Posted February 12, 2024 Quote For any strange reason every time an scheduled Library Scan Runs, the tv shows added to folder 3 are re-added with the scan date of the scheduled task (I have my schedule daily at 3am in the morning) Then this is probably what we should focus on. What makes you think they're being readded?
DarkStar1977 120 Posted February 12, 2024 Author Posted February 12, 2024 11 hours ago, Luke said: Then this is probably what we should focus on. What makes you think they're being readded? Because are every day in the morning always those as the latest shows added ?
Luke 42237 Posted February 18, 2024 Posted February 18, 2024 On 2/12/2024 at 1:06 PM, DarkStar1977 said: Because are every day in the morning always those as the latest shows added ? OK, please provide a specific example, along with the server log that spans from the night before until the time you noticed the problem in the morning. Thanks.
DarkStar1977 120 Posted March 20, 2024 Author Posted March 20, 2024 @Lukehaving no season visible for 1 season shows present an issue: If you have already seen the season you need to go episode by episode marking it as viewed, as you don't have the option to mark the season as viewed you can only mark the entire show or going episode by episode marking it as viewed. This is not an issue when the show has only one season and it's finished BUT has a great impact on shows that TODAY have a season but a new season will come. If you marked it viewed at show level, the new season will be marked authomatically as viewed, otherwise you need to teach all users to go episode by episode marking those as viewed, something very anoying when a season has +10 episodes that you've already seen. I see 2 solutions: 1.- Reenable the option to see the season in "1 season" shows 2.- When you mark as viewed the show, will only mark the existing episodes as viewed but will not affect to new ones. In fact, Pllex uses behaviour described in option 2, no matter what you mark as viewed (show, season), only affects to episodes that are present in the server but does not affect future added episodes.
Luke 42237 Posted March 20, 2024 Posted March 20, 2024 Quote If you marked it viewed at show level, the new season will be marked authomatically as viewed, otherwise you need to teach all users to go episode by episode marking those as viewed, something very anoying when a season has +10 episodes that you've already seen. Hi, this may have been true in 4.7 but will not happen anymore in 4.8. The entire feature that was causing this doesn't exist anymore.
Luke 42237 Posted March 27, 2024 Posted March 27, 2024 On 3/20/2024 at 1:04 AM, Luke said: Hi, this may have been true in 4.7 but will not happen anymore in 4.8. The entire feature that was causing this doesn't exist anymore. Does this answer your question?
DarkStar1977 120 Posted March 27, 2024 Author Posted March 27, 2024 16 hours ago, Luke said: Does this answer your question? Yes and no, I know how to acces by web but does not solves the issue that started everything, and is that after the upgrade, from native Apple and Android applications, embyconnect login was not recognized, that forced me to create a local password for each user, after that, they have to reset their embyconnect password and then worked.
DarkStar1977 120 Posted April 15, 2024 Author Posted April 15, 2024 On 4/11/2024 at 10:06 PM, Luke said: Is this resolved now? Yes. Thanks
