HawkXP71 112 Posted February 7, 2024 Posted February 7, 2024 The server is running on windows 11, the media is on a Synology NAS via SMB If I manually scan the libraries, all is good. Enable real time monitoring is on the library settings However, adding media or changing the directory structure, or even doing a "touch" on a filename to create a new file does nothing. Any ideas on how to track this down?
Luke 42184 Posted February 7, 2024 Posted February 7, 2024 Hi there, let's look at a specific example: How to Report a Problem Thanks.
HawkXP71 112 Posted February 7, 2024 Author Posted February 7, 2024 Step 1: ssh into NAS Step 2: cd to root of TV video Step 3: Inside Emby, rotate the log Step 4: in the shell at the root of TV # touch fubar.mkv Step 5: Send log showing nothing. 2024-02-06 18:08:42.267 Info App: Emby Server Version: 4.8.0.80 2024-02-06 18:08:42.267 Info App: Emby Command line: C:\Emby-Server\system\EmbyServer.dll -service Operating system: Microsoft Windows 10.0.22631 Framework: .NET 6.0.26 OS/Process: x64/x64 Runtime: C:/Emby-Server/system/System.Private.CoreLib.dll Processor count: 20 Data path: C:\Emby-Server\programdata Application path: C:\Emby-Server\system 2024-02-06 18:08:42.267 Info App: Logs path: C:\Emby-Server\programdata\logs 2024-02-06 18:08:42.267 Info App: Cache path: C:\Emby-Server\programdata\cache 2024-02-06 18:08:42.267 Info App: Internal metadata path: C:\Emby-Server\programdata\metadata 2024-02-06 18:08:42.267 Info App: Transcoding temporary files path: c:\EmbyTemp\transcoding-temp 2024-02-06 18:08:42.267 Info App: Plugins: Auto Movie Version Collections 1.0.0.0 Backup & Restore 1.6.1.0 Bluray Folder Support 1.0.2.0 Cinema Intros 1.0.47.0 Diagnostics PlugIn 4.8.0.58 Disk Space 1.0.6.1 DLNA 1.3.7.0 Dvd Folder Support 1.0.0.0 Emby Guide Data 1.0.12.0 Fanart.tv 1.0.16.0 Folder Sync 3.2.6.0 M3U TV Tuner 1.0.20.0 Movie Theme Songs 1.7.5.0 Movie Theme Videos 1.7.5.0 MovieDb 1.7.4.0 MusicBrainz 1.0.22.0 Nfo Metadata 1.0.79.0 OMDb 1.0.21.0 Open Subtitles 1.0.51.0 Playback Reporting 2.1.0.5 Port Mapper 1.2.4.0 Reports 1.0.50.0 Statistics 3.1.1.0 Studio Images 1.0.3.0 TheAudioDb 1.0.18.0 Theme Songs 1.6.6.7 TheTVDB 1.4.5.0 TV Theme Videos 1.7.5.0 Webhooks 1.0.35.0 XmlTV 1.1.6.0 2024-02-06 18:08:42.267 Info TaskManager: Rotate log file Completed after 0 minute(s) and 0 seconds 2024-02-06 18:10:01.050 Info LibraryMonitor: TV (\\mediabox\videos\TV) will be refreshed. 2024-02-06 18:10:03.416 Info Server: http/1.1 POST http://emby_remote_ip/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=2f0cac4c-6191-457d-af2b-2b6c53c55b35&X-Emby-Client-Version=4.8.0.80&X-Emby-Token=x_secret5_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-06 18:10:03.416 Info Server: http/1.1 Response 204 to host7. Time: 0ms. POST http://emby_remote_ip/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=2f0cac4c-6191-457d-af2b-2b6c53c55b35&X-Emby-Client-Version=4.8.0.80&X-Emby-Token=x_secret5_x&X-Emby-Language=en-us&reqformat=json
Luke 42184 Posted February 7, 2024 Posted February 7, 2024 Looks like you added an smb share directly to Emby. Emby's built-in smb support doesn't support the realtime monitor. What you should do is instead use Synology's support by mounting the smb share to a local path in Synology, then add the local path into Emby Server instead of the SMB share. That still doesn't guarantee it will be supported because it needs to be something that INotify supports, but it at least gives you a better shot.
HawkXP71 112 Posted February 7, 2024 Author Posted February 7, 2024 59 minutes ago, Luke said: Looks like you added an smb share directly to Emby. Emby's built-in smb support doesn't support the realtime monitor. What you should do is instead use Synology's support by mounting the smb share to a local path in Synology, then add the local path into Emby Server instead of the SMB share. That still doesn't guarantee it will be supported because it needs to be something that INotify supports, but it at least gives you a better shot. The Server is running on windows, and has a SMB path to a linux synology box. Im not sure what you mean by "use Synology's support by mounting the smb share to the local path in Synology, then add the local path into emby server" Thanks
Luke 42184 Posted February 7, 2024 Posted February 7, 2024 https://kb.synology.com/en-id/DSM/help/FileStation/mountremotevolume?version=7
HawkXP71 112 Posted February 7, 2024 Author Posted February 7, 2024 I can a mount from the windows emby server onto the synology box, I get. But how would that create a local path on the emby server?
Luke 42184 Posted February 7, 2024 Posted February 7, 2024 Sorry, my mistake. Server on windows. So forget everything I said. So from my experience, there is very limited realtime monitor support for network paths when the server is running on windows. At minimum I think both machines need to be running windows, but I generally wouldn't expect it to work.
HawkXP71 112 Posted February 7, 2024 Author Posted February 7, 2024 Just now, Luke said: Sorry, my mistake. Server on windows. So forget everything I said. So from my experience, there is very limited realtime monitor support for network paths when the server is running on windows. At minimum I think both machines need to be running windows, but I generally wouldn't expect it to work. OK. thanks. For work, I have worked on a number of solutions for this, for cross platform file monitoring. One solution that worked, is on a per directory basis, storing the last timestamp in a file, then checking the directory against that timestamp on the half hour or so. Expensive but could be done in a background thread
HawkXP71 112 Posted February 7, 2024 Author Posted February 7, 2024 I had also written a mini server at one point, where you gave it a list of directories to monitor, and it ran in the background. It could be queried to see if any file or dir had changed. Essentially it worked using rpc or network calls. But it wouldn't be any better than a multithreaded solution. 1
adminExitium 356 Posted February 7, 2024 Posted February 7, 2024 You may want to try using this: https://github.com/Cloudbox/autoscan/ Run it on the NAS (may need to be run on the host rather than via docker) and specify the connection details of the Windows Emby Server.
HawkXP71 112 Posted February 9, 2024 Author Posted February 9, 2024 On 2/7/2024 at 12:38 AM, adminExitium said: You may want to try using this: https://github.com/Cloudbox/autoscan/ Run it on the NAS (may need to be run on the host rather than via docker) and specify the connection details of the Windows Emby Server. Thanks. very interesting.
HawkXP71 112 Posted February 11, 2024 Author Posted February 11, 2024 (edited) @Lukeand others who might need this. here is my solution. I created a triggered task that runs the following script MONITORDIR=/volume1/videos inotifywait -m -r -e create,modify --format '%w%f' /volume1/videos /volume1/photos /volume1/music | while read NEWFILE; do curl -X 'POST' \ "http://server:serverport/emby/Library/Refresh?api_key=myapikey" \ -H 'accept: */*' \ -d '' sleep 10m done Essentially anytime any file into any of my library directories, it posts a refresh call to the server. Works like a charm, the sleep just prevents it from happening too often when multiple files are copied/modified at once It may not need modified, but it doesnt hurt. I wish there was a way to get the name of the process (or even the process ID) that did the mod/creation. I would then filter out emby/ffmpeg etc. Edited February 11, 2024 by HawkXP71 1 1
reyist 0 Posted May 20, 2024 Posted May 20, 2024 (edited) @HawkXP71 (First of all sorry for my English) Thanks for the script. With some modifications it worked on my synology nas. But I have another media library with thousands of home photos and videos and this script also starts scanning them. I would like to exclude this particular library from being scanned Is there a way to modify the script to avoid scanning this specific library? Edited May 20, 2024 by reyist
HawkXP71 112 Posted May 20, 2024 Author Posted May 20, 2024 1 hour ago, reyist said: @HawkXP71 (First of all sorry for my English) Thanks for the script. With some modifications it worked on my synology nas. But I have another media library with thousands of home photos and videos and this script also starts scanning them. I would like to exclude this particular library from being scanned Is there a way to modify the script to avoid scanning this specific library? I think using the /items/{id}/refresh API you should be able to create individual inotifiywait commands
reyist 0 Posted June 10, 2024 Posted June 10, 2024 With chat gpt did this: #!/bin/bash EMBY_SERVER="http://192.168.1.3:8096" API_KEY="1234567890" MOVIES_LIBRARY_ID="6153" TV_LIBRARY_ID="7245" LAST_UPDATE_FILE="/tmp/emby_last_update" # Function to send an update request update_library() { local ITEM_ID=$1 local LIBRARY_PATH=$2 local CURRENT_TIME=$(date +%s) local LAST_UPDATE=0 # Check the last update time if [ -f "$LAST_UPDATE_FILE" ]; then LAST_UPDATE=$(cat "$LAST_UPDATE_FILE") if # If enough time has passed since the last update, update the library if [ $((CURRENT_TIME - LAST_UPDATE) -gt 300 ]; then # 300 seconds (5 minutes) delay. echo $CURRENT_TIME > "$LAST_UPDATE_FILE curl -X 'POST' \. "$EMBY_SERVER/emby/Items/$ITEM_ID/Refresh?Recursive=true&ImageRefreshMode=Default&MetadataRefreshMode=Default&ReplaceAllImages=false&ReplaceAllMetadata=false&api_key=$API_KEY"" \ -H 'Accept: */*' \ -d '' else echo "The last update was too recent. Skip the update." fi } # Main intercept loop /opt/bin/inotifywait -m -r -e create,modify,delete --format '%w%f' /volume1/data/media/movies /volume1/data/media/tv | while reading NEWFILE; do if [[ "$NEWFILE" == /volume1/data/media/movies/* ]]]; then update_library "$MOVIES_LIBRARY_ID" "/volume1/data/media/movies" elif [[ "$NEWFILE" == /volume1/data/media/tv/* ]]; then update_library "$TV_LIBRARY_ID" "/volume1/data/media/tv" if done
