Hispanico957 23 Posted February 6, 2024 Posted February 6, 2024 (edited) My friend (on wifi 5.0) has major problems with playback movies in 4K... movies stutter and freeze. On my server i see this: Restarting after playback error Bitrate reduction due to quality settings Restarting after playback error How i can solve this ? Thank Hispa Download.rar Edited February 6, 2024 by Hispanico957
Luke 42243 Posted February 6, 2024 Posted February 6, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Hispanico957 23 Posted February 7, 2024 Author Posted February 7, 2024 (edited) Enclosed my server log and note: My friend play these 4K movies: 13 Hours - The Secret Soldiers of Benghazi 12 soldiers Quel treno per Yuma (2007) 4K.mkv user: BeppeA Time: 22:15 My friend send log debug Await your reply Thank Hispa Download.rar Edited February 7, 2024 by Hispanico957
Luke 42243 Posted February 8, 2024 Posted February 8, 2024 Hi, what are you running Emby Server on? It looks like your server machine just can't transcode this quickly enough to be playable.
Hispanico957 23 Posted February 8, 2024 Author Posted February 8, 2024 (edited) 5 ore fa, Luca ha detto: Ciao, su cosa stai utilizzando Emby Server? Sembra che il tuo computer server non riesca a transcodificarlo abbastanza velocemente da essere riproducibile. My Emby server is on QNAP TS-451D2 Hispa Edited February 8, 2024 by Hispanico957
rbjtech 5341 Posted February 8, 2024 Posted February 8, 2024 3 hours ago, Hispanico957 said: My Emby server is on QNAP TS-451D2 Hispa And there is your answer - your NAS simply does not have enough processing power to transcode the 4K file in real time required for playback. Alternatives are increase bandwidth on your upload/their download to ensure it can 'Direct Play' - and does not need to transcode. use multi copies (4k and non-4k and then restrict the 4k ones to local only) Buy newer hardware - many more modern NAS devices have more powerful hardware inside (with Quicksync) allowing on the fly transcoding without issues. If you enter the world of 4K, you need the equipment in order to play/share it I'm afraid ...
Hispanico957 23 Posted February 8, 2024 Author Posted February 8, 2024 (edited) 1 hour ago, rbjtech said: And there is your answer - your NAS simply does not have enough processing power to transcode the 4K file in real time required for playback. Alternatives are increase bandwidth on your upload/their download to ensure it can 'Direct Play' - and does not need to transcode. use multi copies (4k and non-4k and then restrict the 4k ones to local only) Buy newer hardware - many more modern NAS devices have more powerful hardware inside (with Quicksync) allowing on the fly transcoding without issues. If you enter the world of 4K, you need the equipment in order to play/share it I'm afraid ... PLS my QNAP is a modern NAS also equipped with Quicksync (for your information QuickSync work through Qnap app nas-Client) Specific: Intel® Celeron® J4025 2-core/2-thread, 2,9 GHz. 4GB flash memory and with 8GB ram, 64-bit x86, Intel® HD Graphics 600 https://www.qnap.com/it-it/product/ts-451d2/specs/hardware Hispa P.S. this problem happened with an user connect with wifi Edited February 8, 2024 by Hispanico957
rbjtech 5341 Posted February 8, 2024 Posted February 8, 2024 (edited) Sorry, yes you are correct, although it's a 7 year old cpu/gpu, the HD Graphics 600 does surprisingly have Quicksync. I wrongly assumed it didn't. However - looking at the ffmpeg log, even using quicksync (I guess a very early version of it), it is not able to process the video above 1.0x - ie realtime. For flawless transcoding - you realistically need at least 1.5x, ideally 2x. 22:22:53.573 elapsed=00:00:51.61 frame= 877 fps= 17 q=-0.0 size=N/A time=00:00:36.73 bitrate=N/A throttle=off speed=0.712x 22:22:54.116 elapsed=00:00:52.15 frame= 889 fps= 17 q=-0.0 size=N/A time=00:00:37.47 bitrate=N/A throttle=off speed=0.718x 22:22:54.672 elapsed=00:00:52.71 frame= 901 fps= 17 q=-0.0 size=N/A time=00:00:37.63 bitrate=N/A throttle=off speed=0.714x 22:22:55.218 elapsed=00:00:53.25 frame= 913 fps= 17 q=-0.0 size=N/A time=00:00:38.14 bitrate=N/A throttle=off speed=0.716x 22:22:55.754 elapsed=00:00:53.76 frame= 924 fps= 17 q=-0.0 size=N/A time=00:00:38.62 bitrate=N/A throttle=off speed=0.718x 22:22:56.300 elapsed=00:00:54.31 frame= 934 fps= 17 q=-0.0 size=N/A time=00:00:39.13 bitrate=N/A throttle=off speed=0.721x Edited February 8, 2024 by rbjtech
Hispanico957 23 Posted February 8, 2024 Author Posted February 8, 2024 30 minutes ago, rbjtech said: Siamo spiacenti, sì, hai ragione, anche se è una CPU/gpu vecchia di 7 anni, l'HD Graphics 600 ha sorprendentemente Quicksync. Ho erroneamente pensato che non fosse così. Tuttavia, osservando il registro di ffmpeg, anche utilizzando QuickSync (suppongo una versione molto precoce), non è in grado di elaborare il video superiore a 1.0x, ovvero in tempo reale. Per una transcodifica impeccabile: realisticamente hai bisogno di almeno 1,5x, idealmente 2x. These are my settings/option... PLS in which way i can solve ? Thank Hispa
rbjtech 5341 Posted February 8, 2024 Posted February 8, 2024 6 minutes ago, Hispanico957 said: These are my settings/option... PLS in which way i can solve ? Same options as I originally said - your hardware unfortunately cannot transode quickly enough - so any one of the options below would resolve. 2 hours ago, rbjtech said: And there is your answer - your NAS simply does not have enough processing power to transcode the 4K file in real time required for playback. Alternatives are increase bandwidth on your upload/their download to ensure it can 'Direct Play' - and does not need to transcode. use multi copies (4k and non-4k and then restrict the 4k ones to local only) Buy newer hardware - many more modern NAS devices have more powerful hardware inside (with Quicksync) allowing on the fly transcoding without issues. If you enter the world of 4K, you need the equipment in order to play/share it I'm afraid ...
Luke 42243 Posted February 8, 2024 Posted February 8, 2024 You could also try using the quicksync options instead of vaapi.
Hispanico957 23 Posted February 8, 2024 Author Posted February 8, 2024 1 hour ago, Luke said: You could also try using the quicksync options instead of vaapi. In which way? deseleting all Vaapi and left only quicksync ? Thank Hispa
Luke 42243 Posted January 19 Posted January 19 For video stuttering, please try Emby for Android 3.5.25 and let us know how that compares: https://emby.media/emby-for-android.html Thanks.
