mabenan 0 Posted February 6, 2024 Posted February 6, 2024 (edited) Hi, my problem is the following I have a the following folder sturcture Series (YEAR) [tvdbid=123] SEASON 01 SEASON 02 SEASON 03 SEASON 04 Episode S04E22 - Something SEASON 05 SEASON 06 SEASON 07 Episode S07E23 - Something else The season structure and sorting is based on the DVD order of the TVDB. I have also set setting in the season immediately after it appeared in the Library. The sorting also works correct and the Titles and everything are displayed correct. The only thing not working is that for Example Episode S04E22 (DVD Order) is Episode S07E23 (Aired order) but there is also an Episode S07E23 in the DVD order which of course are not the same episode. But Emby puts the file SEASON 07/Episode S07E23 as an alternative Version of SEASON 04/Episode S04E22. For me it looks like for finding alternative Versions all sortings (aired, dvd, absolute) are taken into account. My Server version is 4.8.0.80 on Docker linux Edited February 6, 2024 by mabenan
Abobader 3484 Posted February 6, 2024 Posted February 6, 2024 Hello mabenan, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
rbjtech 5335 Posted February 6, 2024 Posted February 6, 2024 (edited) 7 hours ago, mabenan said: Hi, my problem is the following I have a the following folder sturcture Series (YEAR) [tvdbid=123] SEASON 01 SEASON 02 SEASON 03 SEASON 04 Episode S04E22 - Something SEASON 05 SEASON 06 SEASON 07 Episode S07E23 - Something else The season structure and sorting is based on the DVD order of the TVDB. I have also set setting in the season immediately after it appeared in the Library. The sorting also works correct and the Titles and everything are displayed correct. The only thing not working is that for Example Episode S04E22 (DVD Order) is Episode S07E23 (Aired order) but there is also an Episode S07E23 in the DVD order which of course are not the same episode. But Emby puts the file SEASON 07/Episode S07E23 as an alternative Version of SEASON 04/Episode S04E22. For me it looks like for finding alternative Versions all sortings (aired, dvd, absolute) are taken into account. My Server version is 4.8.0.80 on Docker linux If you set the order(to DVD) after adding it - then you may need to do a metadata refresh on that show to start the metadata collection again - this time in the correct order. Edited February 6, 2024 by rbjtech 1
mabenan 0 Posted February 6, 2024 Author Posted February 6, 2024 Doesn't help the episode still shows a version dropdown with the two files
rbjtech 5335 Posted February 6, 2024 Posted February 6, 2024 (edited) 3 minutes ago, mabenan said: Doesn't help the episode still shows a version dropdown with the two files Unjoin them ('Split versions apart' in a web browser) - then repeat. Edited February 6, 2024 by rbjtech
