Tomiliy 1 Posted February 5, 2024 Posted February 5, 2024 Hello, I have recently installed the new version 4.8.0.80 on my Synology 423+. Actually, everything went well until I wanted to record something today. The recording somehow didn't work at all. It also wrote in the settings of the series recording that this program will NOT be recorded, without any explanation. Manual recording did not work either. Log files are attached. Maybe you can see something Thank you embyserver.txt : 2024-02-05 00:00:00.087 Info App: Emby Server Version: 4.8.0.80 2024-02-05 00:00:00.088 Info App: Emby Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build5) (gcc version 12.2.0 (GCC) ) #69057 SMP Fri Jan 12 17:02:28 CST 2024 Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system 2024-02-05 00:00:00.088 Info App: Logs path: /var/packages/EmbyServer/var/logs 2024-02-05 00:00:00.088 Info App: Cache path: /var/packages/EmbyServer/var/cache 2024-02-05 00:00:00.088 Info App: Internal metadata path: /var/packages/EmbyServer/var/metadata 2024-02-05 00:00:00.088 Info App: Transcoding temporary files path: /var/packages/EmbyServer/var/transcoding-temp 2024-02-05 00:00:00.088 Info App: Plugins: Backup & Restore 1.6.1.0 Bluray Folder Support 1.0.2.0 Cinema Intros 1.0.47.0 DLNA 1.3.7.0 Dvd Folder Support 1.0.0.0 Emby Guide Data 1.0.12.0 Fanart.tv 1.0.16.0 Kodi companion 2.2.1.0 M3U TV Tuner 1.0.20.0 MovieDb 1.7.4.0 MusicBrainz 1.0.22.0 Nfo Metadata 1.0.79.0 OMDb 1.0.21.0 Open Subtitles 1.0.51.0 Port Mapper 1.2.4.0 Security Cams 1.0.0.0 Studio Images 1.0.3.0 TheAudioDb 1.0.18.0 TheTVDB 1.4.5.0 VuPlus 3.2.9.0 Webhooks 1.0.35.0 XmlTV 1.1.6.0 2024-02-05 22:13:08.787 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_343.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:08.796 Info Server: http/1.1 Response 200 to host3. Time: 9ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_343.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:12.735 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:12.738 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:12.770 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_344.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:12.779 Info Server: http/1.1 Response 200 to host3. Time: 10ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_344.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:13.386 Info Server: http/1.1 POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2024-02-05 22:13:13.388 Info Server: http/1.1 Response 204 to host3. Time: 2ms. POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress 2024-02-05 22:13:16.771 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:16.774 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:16.802 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_345.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:16.805 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_345.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:20.804 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:20.807 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:20.836 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_346.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:20.847 Info Server: http/1.1 Response 200 to host3. Time: 11ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_346.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:20.873 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_347.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:20.877 Info Server: http/1.1 Response 200 to host3. Time: 4ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_347.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:23.386 Info Server: http/1.1 POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2024-02-05 22:13:23.388 Info Server: http/1.1 Response 204 to host3. Time: 2ms. POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress 2024-02-05 22:13:24.837 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:24.840 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:24.862 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_348.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:24.884 Info Server: http/1.1 Response 200 to host3. Time: 22ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_348.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:28.863 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:28.866 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:28.895 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_349.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:28.910 Info Server: http/1.1 Response 200 to host3. Time: 16ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_349.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:28.939 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_350.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:28.973 Info Server: http/1.1 Response 200 to host3. Time: 34ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_350.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:32.899 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:32.902 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:32.932 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_351.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:32.961 Info Server: http/1.1 Response 200 to host3. Time: 29ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_351.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:33.394 Info Server: http/1.1 POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2024-02-05 22:13:33.396 Info Server: http/1.1 Response 204 to host3. Time: 2ms. POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress 2024-02-05 22:13:36.932 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:36.935 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:36.967 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_352.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:37.014 Info Server: http/1.1 Response 200 to host3. Time: 47ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_352.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:40.968 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:40.971 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:41.004 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_353.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:41.047 Info Server: http/1.1 Response 200 to host3. Time: 43ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_353.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:41.081 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_354.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:41.114 Info Server: http/1.1 Response 200 to host3. Time: 34ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_354.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:43.375 Info Server: http/1.1 POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2024-02-05 22:13:43.376 Info Server: http/1.1 Response 204 to host3. Time: 2ms. POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress 2024-02-05 22:13:45.005 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:45.008 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:45.039 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_355.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:45.063 Info Server: http/1.1 Response 200 to host3. Time: 24ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_355.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:49.039 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:49.043 Info Server: http/1.1 Response 200 to host3. Time: 5ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:49.067 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_356.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:49.109 Info Server: http/1.1 Response 200 to host3. Time: 42ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_356.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:53.068 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:53.071 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:53.093 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_357.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:53.127 Info Server: http/1.1 Response 200 to host3. Time: 34ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_357.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:53.166 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_358.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:53.185 Info Server: http/1.1 Response 200 to host3. Time: 19ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_358.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:13:53.399 Info Server: http/1.1 POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2024-02-05 22:13:53.401 Info Server: http/1.1 Response 204 to host3. Time: 2ms. POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress 2024-02-05 22:13:57.093 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:13:57.097 Info Server: http/1.1 Response 200 to host3. Time: 4ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:13:57.131 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_359.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:13:57.177 Info Server: http/1.1 Response 200 to host3. Time: 46ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_359.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:14:00.000 Info LiveTV: Recording timer fired for 72cac96d1ce7ae3c6dc17a497a259e85 Naked Attraction. 2024-02-05 22:14:00.021 Info LiveTV: Found existing series based on path: 70470 2024-02-05 22:14:00.021 Info LiveTV: Found existing series based on path: Naked Attraction 2024-02-05 22:14:00.021 Info LiveTV: Getting media sources for recording from channel 46903 TLC HD to record to /volume1/Video/Aufnahmen/Naked Attraction/Naked Attraction 2024_02_05_22_15_00 - Maik & Aimee (7) Doku-Soap, D 2023.ts 2024-02-05 22:14:00.077 Info LiveTV: Opening live stream for recording from channel 46903 TLC HD to /volume1/Video/Aufnahmen/Naked Attraction/Naked Attraction 2024_02_05_22_15_00 - Maik & Aimee (7) Doku-Soap, D 2023.ts 2024-02-05 22:14:00.077 Info LiveTvManager: Opening channel stream, external channel Id: m3u_80ea1f7839ce60313384def40a81e6ae1:0:19:C394:2727:F001:FFFF018A:0:0:0: 2024-02-05 22:14:00.077 Info LiveTV: Streaming Channel m3u_80ea1f7839ce60313384def40a81e6ae1:0:19:C394:2727:F001:FFFF018A:0:0:0:, with streamId: cd4e24cbe265de2560e09323b54e284d 2024-02-05 22:14:00.110 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from http://host5:8001/x_path7_x 2024-02-05 22:14:00.111 Info HttpClient: GET http://host5:8001/x_path7_x 2024-02-05 22:14:00.116 Info HttpClient: Http response 200 from http://host5:8001/x_path7_x after 6ms. Headers Connection=close, Server=streamserver 2024-02-05 22:14:00.116 Info SharedHttpPipelineSource: Live stream buffer limit is unlimited. 2024-02-05 22:14:00.153 Info SharedHttpPipelineSource: Start waiting for the live stream buffer to fill 2024-02-05 22:14:00.153 Info SharedHttpPipelineSource: Beginning SharedHttpPipelineSource stream to /var/packages/EmbyServer/var/transcoding-temp/3180a5d5da344e53ab209a319226e952/{0:0000000}.ts 2024-02-05 22:14:00.220 Info SharedHttpPipelineSource: start copying from response stream: http://gbquad4k:8001/1:0:19:C394:2727:F001:FFFF018A:0:0:0: 2024-02-05 22:14:00.220 Info SharedHttpPipelineSource: Finished copying from response stream: http://gbquad4k:8001/1:0:19:C394:2727:F001:FFFF018A:0:0:0: 2024-02-05 22:14:00.220 Info SharedHttpPipelineSource: Retry opening stream http://host5:8001/x_path7_x 2024-02-05 22:14:00.220 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from http://host5:8001/x_path7_x 2024-02-05 22:14:00.220 Info HttpClient: GET http://host5:8001/x_path7_x 2024-02-05 22:14:00.226 Info HttpClient: Http response 200 from http://host5:8001/x_path7_x after 6ms. Headers Connection=close, Server=streamserver 2024-02-05 22:14:00.226 Info SharedHttpPipelineSource: start copying from response stream: http://gbquad4k:8001/1:0:19:C394:2727:F001:FFFF018A:0:0:0: 2024-02-05 22:14:00.226 Info SharedHttpPipelineSource: Finished copying from response stream: http://gbquad4k:8001/1:0:19:C394:2727:F001:FFFF018A:0:0:0: 2024-02-05 22:14:00.226 Info SharedHttpPipelineSource: Retry opening stream http://host5:8001/x_path7_x 2024-02-05 22:14:00.226 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from http://host5:8001/x_path7_x 2024-02-05 22:14:00.226 Info HttpClient: GET http://host5:8001/x_path7_x 2024-02-05 22:14:00.233 Info HttpClient: Http response 200 from http://host5:8001/x_path7_x after 7ms. Headers Connection=close, Server=streamserver 2024-02-05 22:14:00.233 Info SharedHttpPipelineSource: start copying from response stream: http://gbquad4k:8001/1:0:19:C394:2727:F001:FFFF018A:0:0:0: 2024-02-05 22:14:00.233 Info SharedHttpPipelineSource: Finished copying from response stream: http://gbquad4k:8001/1:0:19:C394:2727:F001:FFFF018A:0:0:0: 2024-02-05 22:14:00.233 Error SharedHttpPipelineSource: Shut down stream from http://host5:8001/x_path7_x - The operation does not allow more than 2 retries within 00:05:00 2024-02-05 22:14:01.131 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:14:01.134 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:14:01.173 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_360.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:14:01.195 Info Server: http/1.1 Response 200 to host3. Time: 23ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_360.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:14:03.233 Error SharedHttpPipelineSource: Failed to shut down GraphRunner! 2024-02-05 22:14:03.233 Info SharedHttpPipelineSource: SharedHttpPipelineSource is done streaming. 2024-02-05 22:14:03.293 Error GraphRunner: GraphRunnerTimestampFixup: CloseOutput *** Error Report *** Version: 4.8.0.80 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build5) (gcc version 12.2.0 (GCC) ) #69057 SMP Fri Jan 12 17:02:28 CST 2024 Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.TV.TsProcessorLegacy.Runners.GraphRunnerTimestampFixup.CloseOutput(IFileWriter writer, SegmentedStreamSegmentInfo currentFile) Source: Emby.LiveTV TargetSite: Void CloseOutput(Emby.TV.TsProcessorLegacy.DataFlow.Output.IFileWriter, MediaBrowser.Controller.Library.SegmentedStreamSegmentInfo) 2024-02-05 22:14:03.404 Info Server: http/1.1 POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2024-02-05 22:14:03.406 Info Server: http/1.1 Response 204 to host3. Time: 2ms. POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress 2024-02-05 22:14:03.653 Info SharedHttpPipelineSource: Done waiting for segments after 3500ms 2024-02-05 22:14:03.654 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /var/packages/EmbyServer/target/bin/ffprobe -analyzeduration 3000000 -user_agent "VLC/3.0.0-git LibVLC/3.0.0-git" -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/3180a5d5da344e53ab209a319226e952/stream.ts" -threads 0 -v info -print_format json -show_streams -show_format -show_data 2024-02-05 22:14:03.687 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/3180a5d5da344e53ab209a319226e952/stream.ts. Accept=*/*, Connection=close, Host=host6, User-Agent=VLC/3.0.0-git LibVLC/3.0.0-git, Range=bytes=0-, Icy-MetaData=1 2024-02-05 22:14:03.687 Info SharedHttpPipelineSource: Live Stream ended. 2024-02-05 22:14:03.687 Info Server: http/1.1 Response 200 to 127.0.0.1. Time: 0ms. GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/3180a5d5da344e53ab209a319226e952/stream.ts 2024-02-05 22:14:03.689 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 - Succeeded 2024-02-05 22:14:03.812 Error MediaSourceManager: Error probing live tv stream *** Error Report *** Version: 4.8.0.80 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build5) (gcc version 12.2.0 (GCC) ) #69057 SMP Fri Jan 12 17:02:28 CST 2024 Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: ffprobe failed - streams and format are both null: -analyzeduration 3000000 -user_agent "VLC/3.0.0-git LibVLC/3.0.0-git" -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/3180a5d5da344e53ab209a319226e952/stream.ts" -threads 0 -v info -print_format json -show_streams -show_format -show_data ffprobe version 5.1-emby_2023_06_25 Copyright (c) 2007-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 10.3.0 (crosstool-NG 1.25.0) http://127.0.0.1:8096/LiveTv/LiveStreamFiles/3180a5d5da344e53ab209a319226e952/stream.ts: Invalid data found when processing input { } at Emby.Server.MediaEncoding.Probing.MediaProbeManager.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, String userAgent, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean hasMixedProtocols, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.AddMediaInfoWithProbe(MediaSourceInfo mediaSource, Boolean isAudio, Boolean addProbeDelay, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.AddMediaInfoWithProbeSafe(MediaSourceInfo mediaSource, Boolean isAudio, Boolean addProbeDelay, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2024-02-05 22:14:03.812 Info M3UTunerHost: Live stream opened after 3734,2558ms 2024-02-05 22:14:03.812 Info LiveTV: Returning mediasource streamId cd4e24cbe265de2560e09323b54e284d, mediaSource.Id cd4e24cbe265de2560e09323b54e284d, mediaSource.LiveStreamId 2024-02-05 22:14:03.812 Info MediaSourceManager: Live stream opened: {"Protocol":"Http","Id":"cd4e24cbe265de2560e09323b54e284d","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/3180a5d5da344e53ab209a319226e952/stream.ts","Type":"Default","ProbePath":"","ProbeProtocol":"File","Container":"mpegts","IsRemote":false,"HasMixedProtocols":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_cd4e24cbe265de2560e09323b54e284d","RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"VideoRange":"SDR","IsInterlaced":true,"BitRate":10000000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None"},{"IsInterlaced":false,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None"}],"Formats":[],"Bitrate":10000000,"RequiredHttpHeaders":{"User-Agent":"VLC/3.0.0-git LibVLC/3.0.0-git","Referrer":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.61 Safari/537.36"},"AddApiKeyToDirectStreamUrl":false,"ReadAtNativeFramerate":false} 2024-02-05 22:14:03.812 Info LiveTV: Recording ensure file unique input: /volume1/Video/Aufnahmen/Naked Attraction/Naked Attraction 2024_02_05_22_15_00 - Maik & Aimee (7) Doku-Soap, D 2023.ts 2024-02-05 22:14:03.812 Info LiveTV: Recording ensure file unique result: /volume1/Video/Aufnahmen/Naked Attraction/Naked Attraction 2024_02_05_22_15_00 - Maik & Aimee (7) Doku-Soap, D 2023.ts 2024-02-05 22:14:03.812 Info LiveTV: Will record to /volume1/Video/Aufnahmen/Naked Attraction/Naked Attraction 2024_02_05_22_15_00 - Maik & Aimee (7) Doku-Soap, D 2023.ts for 75.93645269 minutes. 2024-02-05 22:14:03.913 Info LiveTV: Triggering refresh on /volume1/Video/Aufnahmen/Naked Attraction/Naked Attraction 2024_02_05_22_15_00 - Maik & Aimee (7) Doku-Soap, D 2023.ts 2024-02-05 22:14:03.915 Info LiveTV: Refreshing recording parent /volume1/Video/Aufnahmen 2024-02-05 22:14:03.915 Info LiveTV: Copying recording stream to file /volume1/Video/Aufnahmen/Naked Attraction/Naked Attraction 2024_02_05_22_15_00 - Maik & Aimee (7) Doku-Soap, D 2023.ts 2024-02-05 22:14:03.915 Info SharedHttpPipelineSource: Live Stream ended. 2024-02-05 22:14:03.915 Info LiveTV: Recording completed to: /volume1/Video/Aufnahmen/Naked Attraction/Naked Attraction 2024_02_05_22_15_00 - Maik & Aimee (7) Doku-Soap, D 2023.ts 2024-02-05 22:14:03.915 Info MediaSourceManager: Live stream cd4e24cbe265de2560e09323b54e284d consumer count is now 0 2024-02-05 22:14:03.915 Info MediaSourceManager: Closing live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_cd4e24cbe265de2560e09323b54e284d 2024-02-05 22:14:03.915 Info SharedHttpPipelineSource: Closing SharedHttpPipelineSource 2024-02-05 22:14:03.915 Info SharedHttpPipelineSource: Deleting temp files 2024-02-05 22:14:03.915 Info MediaSourceManager: Live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_cd4e24cbe265de2560e09323b54e284d closed successfully 2024-02-05 22:14:03.944 Info LiveTV: Triggering refresh on /volume1/Video/Aufnahmen/Naked Attraction/Naked Attraction 2024_02_05_22_15_00 - Maik & Aimee (7) Doku-Soap, D 2023.ts 2024-02-05 22:14:03.945 Info LiveTV: Refreshing recording parent /volume1/Video/Aufnahmen 2024-02-05 22:14:05.173 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:14:05.176 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:14:05.198 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_361.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:14:05.227 Info Server: http/1.1 Response 200 to host3. Time: 28ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_361.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:14:05.261 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_362.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:14:05.283 Info Server: http/1.1 Response 200 to host3. Time: 22ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_362.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:14:09.200 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:14:09.203 Info Server: http/1.1 Response 200 to host3. Time: 4ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:14:09.225 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_363.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:14:09.241 Info Server: http/1.1 Response 200 to host3. Time: 16ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_363.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:14:13.225 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:14:13.228 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:14:13.250 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_364.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:14:13.274 Info Server: http/1.1 Response 200 to host3. Time: 24ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_364.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:14:13.413 Info Server: http/1.1 POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2024-02-05 22:14:13.414 Info Server: http/1.1 Response 204 to host3. Time: 2ms. POST http://192.168.99.111:8096/emby/Sessions/Playing/Progress 2024-02-05 22:14:17.250 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:14:17.253 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:14:17.276 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_365.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:14:17.299 Info Server: http/1.1 Response 200 to host3. Time: 23ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_365.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e 2024-02-05 22:14:21.277 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=gzip 2024-02-05 22:14:21.280 Info Server: http/1.1 Response 200 to host3. Time: 3ms. GET http://192.168.99.111:8096/emby/videos/46893/live.m3u8?DeviceId=eab87413a264e492&MediaSourceId=3d265a9c3e8a3233cdd4fc395ff90fdd&PlaySessionId=809bcab03344487cbe129aa9d004714e&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3d265a9c3e8a3233cdd4fc395ff90fdd&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,trueHD,dts,dca,dtshd,aac,mp3&VideoBitrate=109616000&AudioBitrate=384000&MaxHeight=2176&AudioStreamIndex=3&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&trueHD-audiochannels=8&dts-audiochannels=8&dca-audiochannels=8&dtshd-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2024-02-05 22:14:21.307 Info Server: http/1.1 GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_366.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e. Connection=keep-alive, Host=host2, User-Agent=Emby/2.0.98g (Linux;Android 11) ExoPlayerLib/2.18.7, Accept-Encoding=identity 2024-02-05 22:14:21.323 Info Server: http/1.1 Response 200 to host3. Time: 16ms. GET http://192.168.99.111:8096/emby/videos/46893/hls/2C8654/2C8654_366.ts?PlaySessionId=809bcab03344487cbe129aa9d004714e ffmpeg-directstream-b2fd0a16-24ac-4e7a-85ef-ca55b88fa1aa_1.txt ffmpeg-directstream-d6d29449-7cb8-48dd-aa87-fc180bdcfb35_1.txt
Solution Luke 42241 Posted February 5, 2024 Solution Posted February 5, 2024 HI, yes we'll be putting out a 4.8.1 release that should resolve this. Thanks.
Tomiliy 1 Posted February 6, 2024 Author Posted February 6, 2024 Perfekt, thanks. So you know when the Release comes for Synology? Thanks
