scott46953 31 Posted May 22, 2024 Posted May 22, 2024 (edited) mine keep re-recording eps of shows that have already been watched and deleted due to [[ Keep up to "30" limit ]] <<example>> that is set. when i look at the future schedule it does not show on the list, if i have watched the ep or not.. until it is already recording the show, then I see the green check mark on the Dashboard screen... This is a waste of resource and space. Is there a plugin or a feature that I am missing? Edit, maybe there is a way to only record EPS of a show 1 time, or a selection to allow it to record X many times before it stops recording EPS of a show? Edited May 22, 2024 by scott46953
Luke 42287 Posted May 25, 2024 Posted May 25, 2024 On 5/22/2024 at 10:30 AM, scott46953 said: mine keep re-recording eps of shows that have already been watched and deleted due to [[ Keep up to "30" limit ]] <<example>> that is set. when i look at the future schedule it does not show on the list, if i have watched the ep or not.. until it is already recording the show, then I see the green check mark on the Dashboard screen... This is a waste of resource and space. Is there a plugin or a feature that I am missing? Edit, maybe there is a way to only record EPS of a show 1 time, or a selection to allow it to record X many times before it stops recording EPS of a show? So you want to skip recording previously watched episodes? There is currently no way to do this, but it's certainly doable.
