mixdkins 4 Posted February 4, 2024 Posted February 4, 2024 Hi, Even though this identifies as 1080p - when I filter movies based on resolution - I see some 1080p movies in the list. This was happening before the upgrade to 4.8 just wondered if this was a known issue - and if there is a fix? Video Title1080p HEVC CodecHEVC Codec Taghev1 ProfileMain 10 Level120 Resolution1418x1080 Aspect Ratio709:540 InterlacedNo Framerate23.976 Bitrate2 mbps Bit Depth10 bit Pixel Formatyuv420p10le Reference Frames1 Honey, I Shrunk The Kids (1989).nfo
Luke 42176 Posted February 4, 2024 Posted February 4, 2024 Hi, we'll take a look at it. Thanks for reporting. 1
Bagul 182 Posted August 8, 2024 Posted August 8, 2024 On 2/5/2024 at 12:45 AM, Luke said: Hi, we'll take a look at it. Thanks for reporting. Hello, The problem still exists even with version 4.8.0.28. 1
tsunami1701 6 Posted May 19, 2025 Posted May 19, 2025 Hi there, I still have problems with resolution filter in version 4.8.11.0
visproduction 328 Posted May 20, 2025 Posted May 20, 2025 The resolution value at the bottom of the Art card for the movie depends on the earliest date added in the .nfo files. If there are two versions 720P and 1080P, open the 1080P .nfo file, look for date added and make the date several years ago. 2025 change to 2020. It should be earlier than the date added for the 720P version in it's .nfo file. Rescan the libraries and your resolution should show 1080P in the Art card poster info. I reported this before, but it still needs a code update to fix. It's probably very low on the to do list. 1
