exus 17 Posted February 4, 2024 Posted February 4, 2024 Hi, I was testing the Smart subtitle mode with my Anime library and it's not working on a lot of my titles. Anime files with the japanese audio track set to "ja-JP" are not recognized as Japanese audio and the "smart" subtitle is not getting selected, If I edit the audio track tag to "jp" (instead of ja-JP) it works. Is this a bug or the ja-JP format is not supported or it's something else? This is the audio mediainfo of the original episode (not working): Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 23 min 40 s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Title : Japanese Language : Japanese (JP) Default : Yes Forced : No VENDOR_ID : [0][0][0][0] And this is the same episode with the edited language tag (working): Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 23 min 40 s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Title : Japanese Language : Japanese Default : Yes Forced : No VENDOR_ID : [0][0][0][0] Thank you
Luke 42184 Posted February 4, 2024 Posted February 4, 2024 Hi, we can add support for ja-JP. Thanks. 1
exus 17 Posted February 8, 2024 Author Posted February 8, 2024 Hi @Luke, I really appreciate the recent fix for ja-Jp (that indeed fixed the issue with the audio track that is now correctly recognized as japanese) but I guess the same problem is happening with the subtitles of the majority of my anime. they all follow the same type of tag and they're not correctly recognized: it-IT en-US and other countries using this repeated subregion specification (IETF - ISO 3166-1 I guess..)
Luke 42184 Posted February 8, 2024 Posted February 8, 2024 5 hours ago, exus said: Hi @Luke, I really appreciate the recent fix for ja-Jp (that indeed fixed the issue with the audio track that is now correctly recognized as japanese) but I guess the same problem is happening with the subtitles of the majority of my anime. they all follow the same type of tag and they're not correctly recognized: it-IT en-US and other countries using this repeated subregion specification (IETF - ISO 3166-1 I guess..) OK that's uncommon and something we'd have to look at in future updates. Thanks.
