Luke 42239 Posted February 26, 2024 Posted February 26, 2024 7 hours ago, sameh1925 said: هل يوجد حل لمشكلتي في هذه النسخه Is there a solution to my problem in this version? @SamES HI, we are looking into it. Thanks. 1
SamES 1084 Posted February 26, 2024 Posted February 26, 2024 On 24/02/2024 at 23:42, sameh1925 said: This is exactly what is needed @SamES هذا هو المطلوب الظبط embyserver.txt 491.54 kB · 5 downloads Yes, this file was exactly what was needed, thanks. We will let you know when we have further information. 1
Luke 42239 Posted March 1, 2024 Posted March 1, 2024 hi, please let us know if Emby Server 4.8.3 helps with your LG playback issue. Thanks ! 1
Solution sameh1925 24 Posted March 2, 2024 Author Solution Posted March 2, 2024 2 hours ago, Luke said: مرحبا ، يرجى إخبارنا إذا كان Emby Server 4.8.3 يساعد في مشكلة تشغيل LG. شكرا! بالفعل نجح الامر بعد التحديث وتم حل المشكله شكرا لك وشكرا لمطورين سيرفر امبي Indeed, it worked after the update and the problem was solved, thank you And thanks to the developers of the Ambi server 1 2
