Luke 42239 Posted February 8, 2024 Posted February 8, 2024 Is there a small video you can provide for testing purposes?
sameh1925 24 Posted February 8, 2024 Author Posted February 8, 2024 37 minutes ago, Luke said: هل هناك فيديو صغير يمكنك تقديمه لأغراض الاختبار؟ هذ اصغر ملف تم ايجاده لا يعمل . مع العلم انني قمت بالترقيه الي 4.8.1.0 وما زالت المشكله كما هي This is the smallest file that has been found not working. Knowing that I upgraded to 4.8.1.0 And the problem is still the same @Lukeسورة الفيل - للأطفال للحفظ مكرر.mkv
sameh1925 24 Posted February 9, 2024 Author Posted February 9, 2024 (edited) ارجو حل سريع يوجد العديد من المشاكل او تساعدوني في الرجوع الي النسخه 4.7.14.0 Please fix it quickly There are many problems or help me downgrade to version 4.7.14.0 @Luke @Abobader ffmpeg-directstream-096fe7c0-de70-4d86-ad03-cec9815d6bcf_1.txt Edited February 9, 2024 by sameh1925
Luke 42239 Posted February 11, 2024 Posted February 11, 2024 HI, are you able to update to Emby for LG 1.0.39? I see you're still on 1.0.37. 1
sameh1925 24 Posted February 11, 2024 Author Posted February 11, 2024 6 hours ago, Luke said: HI, are you able to update to Emby for LG 1.0.39? I see you're still on 1.0.37. التطبيق الخاص بي 1.0.39 وهو الذي يحدث عليه كل المشاكل My App 1.0.39 And he is the one who causes all the problems @Luke
sameh1925 24 Posted February 13, 2024 Author Posted February 13, 2024 تحديث جديد لمشكلتي اكتشفت ان الميديا التي لا تعمل بعد التحديث هي التي تم تحميلها من موقع يويتوب A new update to my problem I discovered that the media that does not work after the update is the one that was downloaded from YouTube @Luke
sameh1925 24 Posted February 16, 2024 Author Posted February 16, 2024 ليه محدش بيرد المشكله بتحصل بس في الميديا التي تم تحميلها من اليوتيوب Why doesn't anyone answer? The problem only happens in the media that was downloaded from YouTube
Abobader 3485 Posted February 16, 2024 Posted February 16, 2024 المطور متى ما وجد حل للمشكلة سيرد عليك 1
Luke 42239 Posted February 16, 2024 Posted February 16, 2024 Hi, have you updated to Emby for LG 1.0.41? Has this helped? 1
sameh1925 24 Posted February 16, 2024 Author Posted February 16, 2024 14 hours ago, Luke said: Hi, have you updated to Emby for LG 1.0.41? Has this helped? تم التحديث طبعا منذ يوم وتمت التجربه وما زالت المشكله كما هي وااكد ان المشكله تحدث فقط للملفات التي تم تحميلها من اليوتيوب وممكن ان تكون المشكله خاصه بتحويل الشفره The update was done of course a day ago and the experiment was done and the problem is still the same I confirm that the problem only occurs to files that were downloaded from YouTube And the problem could be related to transforming the code
Luke 42239 Posted February 16, 2024 Posted February 16, 2024 Can you provide one of these videos for testing? Thanks ! 1
sameh1925 24 Posted February 16, 2024 Author Posted February 16, 2024 1 hour ago, Luke said: Can you provide one of these videos for testing? Thanks ! نوح لسه بيحب تقي يا تري هيرجعو لبعض #حدوتة_منسية.mp4
sameh1925 24 Posted February 21, 2024 Author Posted February 21, 2024 تحديث جديد لدي نوعين من الشاشات ال جي نوع حديث ونوع قديم نوعا ما والاتنينعليهم تطبيق امبي نفس الاصدار تعمل الميديا علي الشاشات الحديثه فقط مع العلم ان الجميع كان يعمل علي نسخه 47.14.0 A new update I have two types of screens, LG is a modern type and a somewhat old type, and the two of them have the Ambi application the same version The media works on modern screens only Knowing that everyone was working on version 47.14.0 @Luke @Abobader 1
SamES 1084 Posted February 22, 2024 Posted February 22, 2024 On 17/02/2024 at 06:45, sameh1925 said: نوح لسه بيحب تقي يا تري هيرجعو لبعض #حدوتة_منسية.mp4 Can you please attach the ffmpeg and server log files for your test of this exact file? I want to compare with my tests. I think you only need to test it on the older TV. Can you please also confirm the model number for the TV? 1
sameh1925 24 Posted February 22, 2024 Author Posted February 22, 2024 (edited) 4 hours ago, SamES said: Can you please attach the ffmpeg and server log files for your test of this exact file? I want to compare with my tests. I think you only need to test it on the older TV. Can you please also confirm the model number for the TV? مرفق اتنين فيدو احدهم لتشغيل نفس الملف علي اللاب توب والاخر لتشغيل نفس الملف علي شاشه ال جي كما مرفق موديل الشاشه ومرفق ايضا سجلات امبي Two videos are attached, one to run the same file on the laptop and the other to play the same file on the LG screen Also attached is the screen model and also attached the records of Emby @SamES @Luke 2024-02-22_16-47-13.mp4 My Video.mp4 embyserver.txt Edited February 22, 2024 by sameh1925
Abobader 3485 Posted February 22, 2024 Posted February 22, 2024 @sameh1925 المطلوب ايضا سجل ffmpeg بعد ان تشغل الفيديو على الشاشة القديمة التى هى سبب المشكلة
sameh1925 24 Posted February 22, 2024 Author Posted February 22, 2024 41 minutes ago, Abobader said: @sameh1925 المطلوب ايضا سجل ffmpeg بعد ان تشغل الفيديو على الشاشة القديمة التى هى سبب المشكلة لقد بحثت عنه ولاكن لايتم تسجيله في السجلات
SamES 1084 Posted February 23, 2024 Posted February 23, 2024 If you cannot find any ffmpeg logs then it appears that transcoding is not working for some reason. Can you please try this? Enable debug logging in the 'Settings' page in the Logs section on the server Restart the server Make one test trying to play on the old LG TV the file you provided here https://emby.media/community/index.php?/topic/125587-مشكله-بعد-التحديث/&do=findComment&comment=1328840 Attach a copy of the server log for this test Please let me know what the time was when you made this test so that I can confirm I am checking correctly in the server log. You can then turn of the debug logging on the server once this test is complete. Thanks 1
sameh1925 24 Posted February 23, 2024 Author Posted February 23, 2024 1 hour ago, SamES said: If you cannot find any ffmpeg logs then it appears that transcoding is not working for some reason. Can you please try this? Enable debug logging in the 'Settings' page in the Logs section on the server Restart the server Make one test trying to play on the old LG TV the file you provided here https://emby.media/community/index.php?/topic/125587-مشكله-بعد-التحديث/&do=findComment&comment=1328840 Attach a copy of the server log for this test Please let me know what the time was when you made this test so that I can confirm I am checking correctly in the server log. You can then turn of the debug logging on the server once this test is complete. Thanks بالفعل شغلت تصحيح الاخطاء وبعدها قمت باعاده تشغيل الخادم ومرفق فيدو يوضح هذا ثم قمت بتشغيل الفيدو علي شاشه ال جي وهناك فيدو ايضا يوضح هذا ثم بحثت في السجلات ولاكن لا يوجد اي سجل يخص هذا الملف وهناك فيدو يوضح هذا ايضا I actually ran debugging and then I restarted the server and a video attachment shows this Then I played the Video on the LG screen and there is a Video that also shows this Then I searched the logs, but there is no record related to this file, and there is a video that explains this as well @SamES 2024-02-23_14-43-23.mp4 2024-02-23_14-50-51.mp4 My Video.mp4
SamES 1084 Posted February 24, 2024 Posted February 24, 2024 (edited) 10 hours ago, sameh1925 said: Then I searched the logs, but there is no record related to this file, and there is a video that explains this as well I only need the embyserver log for that test (not any other logs) Edited February 24, 2024 by SamES 1
sameh1925 24 Posted February 24, 2024 Author Posted February 24, 2024 (edited) 10 hours ago, SamES said: I only need the embyserver log for that test (not any other logs) المشكله موجوده في هذا الملف The problem is in this file embyserver-63844243200 embyserver.txt embyserver-63844243200.txt embyserver-63844289004.txt Edited February 24, 2024 by sameh1925
SamES 1084 Posted February 24, 2024 Posted February 24, 2024 (edited) 48 minutes ago, sameh1925 said: The problem is in this file embyserver-63844243200 The line you have highlighted in that file is for playback in the Chrome browser, not the LG TV 2024-02-22 14:46:58.059 Info SessionManager: Playback start reported by app Emby Web 4.8.1.0 playing نوح لسه بيحب تقي يا تري هيرجعو لبعض #حدوتة_منسية. Started at 0 ms I'm also not seeing any debug. Are you sure you enabled this option before testing playback on the LG TV? Can you please check the setting then retry this test: Enable debug logging in the 'Settings' page in the Logs section on the server Restart the server Make one test trying to play on the old LG TV the file you provided here https://emby.media/community/index.php?/topic/125587-مشكله-بعد-التحديث/&do=findComment&comment=1328840 Attach a copy of the embyserver log for this test Thanks Edited February 24, 2024 by SamES 1
sameh1925 24 Posted February 24, 2024 Author Posted February 24, 2024 16 hours ago, SamES said: السطر الذي قمت بتمييزه في هذا الملف مخصص للتشغيل في متصفح Chrome ، وليس تلفزيون LG 2024-02-22 14:46:58.059 مدير جلسة المعلومات: تم الإبلاغ عن بدء التشغيل بواسطة التطبيق Emby Web 4.8.1.0 اللعب نوح لسه بيحب تقي يا تري هيرجعو لبعض #حدوتة_منسية. بدأت في 0 مللي ثانية أنا أيضا لا أرى أي تصحيح. هل أنت متأكد من تمكين هذا الخيار قبل اختبار التشغيل على تلفزيون LG؟ هل يمكنك التحقق من الإعداد ثم إعادة محاولة هذا الاختبار: قم بتمكين تسجيل التصحيح في صفحة "الإعدادات" في قسم السجلات على الخادم أعد تشغيل الخادم قم بإجراء اختبار واحد في محاولة للعب على تلفزيون LG القديم الملف الذي قدمته هنا https://emby.media/community/index.php?/topic/125587-مشكله-بعد-التحديث/&do=findComment&comment=1328840 إرفاق نسخة من سجل embyserver لهذا الاختبار شكرا This is exactly what is needed @SamES هذا هو المطلوب الظبط embyserver.txt 1
sameh1925 24 Posted February 26, 2024 Author Posted February 26, 2024 هل يوجد حل لمشكلتي في هذه النسخه Is there a solution to my problem in this version? @SamES
