PuffyToesToo 348 Posted February 3, 2024 Posted February 3, 2024 Is it possible to have a QR code to scan with your phone when needing to add the PIN for Emby Connect? That way, when you need to login to your Emby Connect, you can just scan that with your phone. Then it takes you to the login page so you can add the PIN it gives you? That would be awesome to do instead of having to type out/copy the entire URL. Thanks for reading. ( I did search if this request already existed and nothing came up). 5
Neminem 1623 Posted February 3, 2024 Posted February 3, 2024 Try with this QR.io: QR Code Generator | Create QR Codes 1
GrimReaper 4898 Posted February 3, 2024 Posted February 3, 2024 (edited) 5 minutes ago, jaycedk said: Try with this QR.io: QR Code Generator | Create QR Codes That wouldn't work in this particular scenario, OP would like to see QR code on the display next to PIN so it could be scanned with mobile phone. Edited February 3, 2024 by GrimReaper 1
ebr 16337 Posted February 3, 2024 Posted February 3, 2024 Hi. We actually do have plans to try and incorporate QR codes in an even better way but this is a good idea in the meantime. 1 1
JoshuaAJones 69 Posted June 17, 2025 Posted June 17, 2025 Let's bump this up. Even if the QR only takes you to the /pin site as a placeholder and I had to type in the numbers myself, this would be helpful, when explaining it to my mom, aunt, etc. It's 2025... they have finally got QR Codes down. Time to implement to keep up with the 70+ generation.
seanbuff 1356 Posted June 17, 2025 Posted June 17, 2025 7 minutes ago, JoshuaAJones said: It's 2025... they have finally got QR Codes down. Time to implement to keep up with the 70+ generation. Some of the clients apps have already implemented this, which one are you not seeing it on?
