suppervinny 1 Posted February 3, 2024 Posted February 3, 2024 Após a atualização de 02/02/2024 várias séries perderam os metadados e aparecem com as temporadas separadas e sem nenhuma imagem, alguns filmes e desenhos também perderam os metadados e mesmo pedindo pro Emby recuperar, não funciona. O sistema está todo quebrado, gostaria de fazer downgrade e voltar pra versão 4.7.14 que funcionava perfeitamente bem. Inclusive, a partir de agora deixarei as atualizações desativadas, pois parecem servir apenas pra prejudicar o bom funcionamento do servidor.
GrimReaper 4843 Posted February 3, 2024 Posted February 3, 2024 (edited) 9 minutes ago, suppervinny said: gostaria de fazer downgrade e voltar pra versão 4.7.14 que funcionava perfeitamente bem Backwards compatibility (especially between different branches, like 4.7 vs 4.8) was never officially supported, unless you have a full backup of your previous installation - you can't downgrade, full rebuild is required. As for your particular issue, it has been already been reported, examples: You might follow those for potential solution(s) for your issues. Edited February 3, 2024 by GrimReaper
suppervinny 1 Posted February 3, 2024 Author Posted February 3, 2024 8 minutos atrás, Peter Nent disse: Por favor inglês.... Use the browser's "translate" button
Luke 42184 Posted February 3, 2024 Posted February 3, 2024 Hi, can you please provide an example of one of those tv series? How are the files named and organized?
rafaeljs84 0 Posted February 5, 2024 Posted February 5, 2024 Good morning! Mine was also disorganized, after the update it lost the metadata of the seasons and chapters. To solve it, I have to go in and have each season identified. The files are organized like this:
Luke 42184 Posted February 6, 2024 Posted February 6, 2024 OK this is caused by the character after the 1 in the season folder name. We'll be getting a 4.8.1 release out to resolve this. Thanks.
