Erik 130 Posted November 2, 2014 Posted November 2, 2014 I create a manual collection in the web client, identify it, save it, then refresh it (even tried advanced refresh). It downloads the title, but doesn't download the overview/poste/backdrop/etc. I can manually browse and select the images and go manually copy the overview, but just wondering if I have set something wrong as none of it is automatic. Thanks, Erik
Solution Erik 130 Posted November 2, 2014 Author Solution Posted November 2, 2014 Nevermind... But in case someone else comes upon this... I missed then when you create a manual collection there was a checkbox to download the data below the text field. Also, if you don't select that box, it locks the newly created collection entry so a refresh doesn't do anything. User induced.
