bitemeoftn 2 Posted February 2, 2024 Posted February 2, 2024 I can't get my server to load at all suddenly. Went from perfect for the last year or so to localhost refused connection. I've tried restarting the PC, running Emby as admin, and have even completely reinstalled to no avail. Fortunately, I have a backup media player in Plex but I like to use Emby for my IPTV. I'm not sure where to go from here. No special configuration was done when making the server and nothing has changed. It just doesn't want to work now.
Abobader 3491 Posted February 2, 2024 Posted February 2, 2024 Hello bitemeoftn, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
user29 2 Posted February 2, 2024 Posted February 2, 2024 I am getting this to (I suspect it has upgraded) - i have tried a reinstall - no avail Emby starts (in the tray) but nothign (apps) connects and it just times out Will wait for advice
bitemeoftn 2 Posted February 2, 2024 Author Posted February 2, 2024 Doesn't seem we're going to be getting too much advice anytime soon. Curious to know how widespread this is. And if it's a fair amount of us why some sort of communication hasn't gone out.
user29 2 Posted February 2, 2024 Posted February 2, 2024 lers give them 24 hours - seems fair! - my install is fairly basic - nothing else on it etc
bitemeoftn 2 Posted February 2, 2024 Author Posted February 2, 2024 Same. I literally installed the server, pointed to a couple of folders, and added in my IPTV URLs. Everything is just stock but even completely uninstalling and reinstalling isn't fixing it at this point. It's worked for the last few months and just decided to crap today.
user29 2 Posted February 2, 2024 Posted February 2, 2024 99% sure its installed the new update in the background (as mine had restarted with a new version number)
ebr 16354 Posted February 2, 2024 Posted February 2, 2024 Hi. Please try removing any 3rd party plugin dlls from your plugins folder and see if that corrects it.
user29 2 Posted February 2, 2024 Posted February 2, 2024 THankyou! I renamed the current plugins to old - and deleted them all - so plugins had nothing in it - still the same.
bitemeoftn 2 Posted February 2, 2024 Author Posted February 2, 2024 No plugins at all here. Just what came with the installation.
kbijvank 58 Posted February 2, 2024 Posted February 2, 2024 Did you check the Windows Firewall and your AV software? I've red somewhere that Emby can get flagged sometimes for some reason.
bitemeoftn 2 Posted February 2, 2024 Author Posted February 2, 2024 Nothing has changed. I've literally installed Emby, pointed to folders for media, put in my IPTV URL's and started watching. Today it randomly decided that it no longer needs to work. However, Plex is just fine and chugging away normally. I hate to make the comparison but it's the best I've got at the moment.
user29 2 Posted February 2, 2024 Posted February 2, 2024 10 minutes ago, kbijvank said: Did you check the Windows Firewall and your AV software? I've red somewhere that Emby can get flagged sometimes for some reason. yes that is all good. I.e i turned it off and same error)
user29 2 Posted February 2, 2024 Posted February 2, 2024 @ebr how do i submit a log - it seems emby is loading then bailing out?
NakedPirate 16 Posted February 2, 2024 Posted February 2, 2024 (edited) Same here! After 4 or 5 restarts it seems to be working now...I had to kill the emby process a few times, didn't start once at all.... PC/emby still pottering around and doing funny things in the background, but everthing seems back at normal. lh:8096 now works relatively fast again. I guess, server still did some sort of update and didn't load on slow systems or maybe DB update? Edited February 2, 2024 by NakedPirate
user29 2 Posted February 2, 2024 Posted February 2, 2024 Emby starts - (say loading) then refuest connection and quits after 6 seconds,
user29 2 Posted February 2, 2024 Posted February 2, 2024 Log Files (from a deletion of logs and a restart) embyserver.txt unhandled_d20d071a-8529-4fee-aa36-5956a1204b4d.txt
snoopy89 0 Posted February 2, 2024 Posted February 2, 2024 I got the same error after update. Logs show: Corrupt: database disk image is malformed Everything was working yesterday, I suspect the issue is related to the update. I tried recovering the database but the recover misses information although the SQL error is fixed.
Solution bitemeoftn 2 Posted February 2, 2024 Author Solution Posted February 2, 2024 I figured it out everyone! All you have to do is completely nuke the entire installation that you built and re-install and set it all back up again and it's all good! I'm sure the sarcasm isn't coming through as strongly as I'd like since this is text (and I'm very fortunate since I had a pretty basic setup). Hopefully someone else finds a better solution but this works for now.
Smashpen 1 Posted February 2, 2024 Posted February 2, 2024 (edited) I suspect anyone without a membership causes an error and this kills the upgrade, closing the web socket and nulling it out. Then it keeps retrying. apiclient.js?v=4.8.0.80:1 WebSocket connection to 'ws://localhost:8096/embywebsocket?api_key=e####&deviceId=3#####' failed: My guess is the QA for the upgrade was only run on member active workstation. It's possible the upgrade will fail for anyone without a license. Edited February 2, 2024 by Smashpen
bitemeoftn 2 Posted February 2, 2024 Author Posted February 2, 2024 An Emby Premiere license? Because I've got one of those.
Luke 42289 Posted February 2, 2024 Posted February 2, 2024 8 hours ago, bitemeoftn said: I can't get my server to load at all suddenly. Went from perfect for the last year or so to localhost refused connection. I've tried restarting the PC, running Emby as admin, and have even completely reinstalled to no avail. Fortunately, I have a backup media player in Plex but I like to use Emby for my IPTV. I'm not sure where to go from here. No special configuration was done when making the server and nothing has changed. It just doesn't want to work now. Is any Emby Server log file generated? Emby Server Data Folder
Luke 42289 Posted February 2, 2024 Posted February 2, 2024 5 hours ago, user29 said: I am getting this to (I suspect it has upgraded) - i have tried a reinstall - no avail Emby starts (in the tray) but nothign (apps) connects and it just times out Will wait for advice @user29in your case, you have something unique going on...copies of your plugin dll files prefixed with a 1: Please go to this folder, delete all files starting with a 1, and I think that will get you back up and running. Then for future reference, try to avoid tampering with the server data folders. 2024-02-03 00:21:51.180 Info App: Loading Emby.Dlna, Version=1.3.7.0, Culture=neutral, PublicKeyToken=null from C:\Users\steve\AppData\Roaming\MediaBrowser-Server\plugins\1Emby.Dlna.dll
bitemeoftn 2 Posted February 2, 2024 Author Posted February 2, 2024 19 minutes ago, Luke said: Is any Emby Server log file generated? Emby Server Data Folder I completely nuked the entire installation and rebuilt. Not how I wanted to fix it but it's working anyway. 1
